Picked up a 02 gt3000. Need some electrical help
   / Picked up a 02 gt3000. Need some electrical help #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
So we just got a nicely used 23 hp gt3000 with a 50" deck. Previous owner complained it kept blowing fuses so we negotiated a sweet deal. I believe that the blown fuse was directly related to the head light bulb having at one point fallen out and melting to the exhaust.
But there is one weirdness in starting that I wanted advice on. Sometimes when I turn the engine over it clicks but does not turn over. The second part is that the amp meter dives to -30 amps( buries the amp needle). I am wondering if this is a symptom af a bad starter switch. Or a bad starter relay? Or.....
Any consistent issue that this might sound like? For the most part I feel this machine has been reasonably maintained and always garraged.
Carl
   / Picked up a 02 gt3000. Need some electrical help #2
Put a volt meter on the battery when you try and start it. If the voltage doesn't change in the crank/no crank tries, the go to the relay and check both the voltage coming from the key switch (S/B battery voltage) and the voltage on both sides of the relay (should not have volt drop across the relay during cranking). That leave the starter motor as the problem if everything else checks out.
Also if you don't have battery voltage coming to the starter relay you will need to check the safety switches as well as the key switch.
I have this old adage when it comes to auto electric. Clean the battery connectors on both sides. Of course my advice to other people is never heeded by me.
Turns out that the newish battery was never tightened down. No wonder it was acting weird.
So... Happy as heck about the deal I got.
   / Picked up a 02 gt3000. Need some electrical help #4
It may well be that valves need adjustment, if the valves get loose enough the compression release doesn't work and the starter is not up to turning it over under full compression. I know, happened to my 26 h.p. B&S.
   / Picked up a 02 gt3000. Need some electrical help #5
This is so true. A friend of mine couldn't start his tractor. He found some info on the net about adjusting the valves. He adjusted the valves and now it starts easily and runs great.
   / Picked up a 02 gt3000. Need some electrical help #6
But there is one weirdness in starting that I wanted advice on. Sometimes when I turn the engine over it clicks but does not turn over. The second part is that the amp meter dives to -30 amps( buries the amp needle). I am wondering if this is a symptom af a bad starter switch. Or a bad starter relay? Or.....Carl
My GT3000 has been doing this for years, sometimes it will take several minutes before the starter finally engages. Reading the previous posts about adjusting the valves, anyone care to share how to do it? I have the 23HP Kohler V-twin
   / Picked up a 02 gt3000. Need some electrical help #7
On my B&S 25 h.p. you just remove the valve covers, measure the gap between the rocker arm and valve tip, loosen the adjusting lock nut and adjust the inner nut until clearance measures to spec with a feeler's gauge. A snug but easy to move gap is correct.;)
   / Picked up a 02 gt3000. Need some electrical help #8
yes pull the valve covers but no no toppop25 you need to pull the plugs rotate the engine tdc then one cylender at a time rotate 1/4 down then adjust them then do the other side
   / Picked up a 02 gt3000. Need some electrical help #9
Yes you do, I knew that as I've done it on everything from my Briggs to 426 Hemi's, but I left it out, sorry!
2597 (A54757)
2597 (A54757)
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
1472 (A51247)
1472 (A51247)
Case 1150G Crawler Tractor Dozer (A53421)
Case 1150G Crawler...
