Antique tractor project
   / Antique tractor project #1
MF1652
Vermont
2016 John Deere 3039R
I have been wanting to get an old tractor for a while now for a fix up project. My fear is I only have basic knowlege when it comes to engines and electrical wiring. I want to take on a project that is not too complicated and build on my knowledge and learn as I go. I figure old machinery would be fun to work on.
Anybody out there have any suggestions on where to start? Any books or manuals anyone has found helpfull for people with basic knowledge?
I have access to an Oliver Super 55 which has not been run for thirty years and has been under cover. It's in rough shape cosmetically but I can handle that. Don't know what the engine would need. Would I be bitting off more than I can handle with this or should I find something else?
   / Antique tractor project #2
You can get the repair manuals from Steiner Tractor Parts. They also stock most of the parts you would need for restoration.
As far as the mechanical aspect if you are mechanically inclined you should be able to fix it. Take lots of pictures so that you know where the parts go after you have taken them all apart.
   / Antique tractor project #3
An old Ford 8N or Ferguson tractor might also make a good first restoration project. They're simple to work on, and easy to get parts for.
After talking with my father he also has a Massey Ferguson 65 and a Ford 9n in addition to the Oliver Super 55 he would let me have. The 9n still has the 6 volt system and other than not being able to start with out a push it runs fine.
I get the impression the 9n would be any easy project to learn on. It's a simple a system and parts seem cheap and readily available.
   / Antique tractor project #5
In my opinion, any one of those models would be good candidates, especially the Ford 9n. If you plan on doing much work with it later, the Massey Ferguson 65 might be a better choice because it's larger and heavier, but as you probably know, each has it's advantages and disadvantages.
If you choose the Ford 9n, don't worry about the 6v electrical system because it's easy to upgrade to a 12v system if you want.
TractorData.com Ford 9N tractor information
TractorData.com Massey Ferguson 65 tractor information
TractorData.com Oliver Super 55 tractor information
   / Antique tractor project #6
Have access? What does that mean? Are you looking to buy the tractor? If so, you need to check out the engine thoroughly before paying good money for something that may turn into a money pit. A few years ago I bought a 1951 Minneapolis Moline BF tractor (25 hp engine) for $1300. No compression on 3 cylinders, 30 psi on the 4th. Engine rebuild cost $800 parts/$800 labor. So check the compression on that Super 55. I'm still reassembling that BF.
Tomorrow I pull the engine on my son's 1948 Farmall Cub--low compression even after regrinding the valves by hand. Needs piston rings, remachining on head and block, main bearings, valve guides, valves. I'll get the estimate later this week.
Here's my 1945 Oliver 60 Row Crop I bought last year for $2250. So far all it's needed is brake relining.
Do you have a garage/shop with concrete floor, engine hoist, gantry crane, floor jacks, jack stands, impact wrench, lotsa hand tools etc. All of these come in real handy when restoring old iron.
Good luck.
Good luck.
When I say "have access" I mean free. All three of these tractors are sitting in storage on my fathers farm and have my pick of either.
As for tools, I have it all with the exception of the gantry crane. I'm pretty mechanical, I just have basic experience with motors and electrical.
By the way flusher, beautiful oliver. I love the sheet metal on those old tractors. They have such a sleek look like it should be on a race track and not in the field. :thumbsup:
   / Antique tractor project #9
I drive it around the field just to keep it lubed--no real work. It's a hanger queen and a parade tractor. Need to replace the temp gauge--when I get time. This week's work is on the Farmall Cub--pull the engine and get it to the engine shop for a complete rebuild.
   / Antique tractor project #10
Do have place thats out of the weather to work?
Can you pace yourself..no bull'n or jam'n.?
Lots info out there on how to for yesterday iron...ebay to you tube.
Try and pick the tractor you always wanted to rebuild..no second choice.
Do keep us updated.
KUBOTA SVL97-2 SKID STEER (A52705)
KUBOTA SVL97-2...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
Ingersoll Rand PKG SS3660V 60 Gallon Air Compressor (A52377)
Ingersoll Rand PKG...
