how to transport a set of drag discs
/ how to transport a set of drag discs #1
MH50
John Deere 820 Massey Harris 50 and others
I have a set of antique pull type discs. I think they are 5 or 6 feet across. I was wondering if anyone has figured out a way to transport these? I need to haul them 2 miles or so down the road to my neighbors.
I want to hook them to my tractor and go. I don't want to trailer them. Thanks for any ideas!
/ how to transport a set of drag discs #2
Best way is to load them on a trailer and pull them on that. Otherwise you could convert it to a transport disc, but that would take some doing.
Aaron Z
/ how to transport a set of drag discs #3
I don't see how you could do it without a trailer or truck. If you have a FEL you may be able to carry it down the road.
/ how to transport a set of drag discs #4
Do you have a picture of the disc in question? If it is small enough (and you have enough front weight), you might be able lift it with a 3 point boom pole while it is attached to the back of the tractor.
Aaron Z
/ how to transport a set of drag discs #5
Back in the "Good Old Days":D they were adjusted so they had no bite and pulled down the road as long as it was dirt. Well, in fact there weren't too many paved roads and that was perfectly acceptable as it only left little narrow cuts that the WD-45 Allis maintainer could take care of the next time it rained. If it ever did. Or you could flip it over and let the frame rest on a skid you just built and drag it with your tractor.
/ how to transport a set of drag discs #6
I use a forklift QA and 3 chains. A chain at each corner to the forklift frame and a long, tight chain about 6" short of the tips of the forklift. And LOTS of ballast. Rolling back the forks lifts the disc.
The tongue is left to hang free on mine but you may need a chain or rope to lift yours in the air to keep it from dragging.
When I used a pin-on bucketed tractor, two chains were draped over the bucket edges fore to aft and hooked to the disc. With the bucket rolled back the edge of the bucket kept the chains from slipping. Not the best or most secure method but it worked.
However, with these set-ups the disc was never hauled more than about a quarter mile.
/ how to transport a set of drag discs #7
That's the way I used to do it when I was a kid on the farm. An old, old set of 10' tandem disc harrows behind an Allis Chalmers WC older than me. Talk about noisy on a gravel road as the discs hit the rocks! I can still hear the fingernails-on-blackboard sound of them when I think back!
/ how to transport a set of drag discs #8
Yep, I am hearing that sound as I type this.
If you have a hay wagon, Id load them on there with a fel. Tow the wagon with the fel tractor, then unload when you get there.
ok thanks for all the ideas, I have a FEL, and a trailer and a truck, but i want to use my farmall H (which doesnt have a FEL) to pull the discs. The road i need to travel is also paved and i have to go through town. I was thiniking about attaching an old trailer axle to the top and rear of the discs and just flipping them over to haul down the road. Maybe someone has done somthing like this?
thanks everyone!
/ how to transport a set of drag discs #11
Easiest and cheapest way is to put down some old cheap lumber in your trailer floor and haul it over there. Having any of this fall off in front of a following vehicle would be bad news.
/ how to transport a set of drag discs #12
I didn't catch how wide these discs are, but I have an idea.
Load them on your trailer at your farm with a FEL. Put them on the back of the trailer with the discs facing backwards. Back the trailer into a bank when you get to your destination, back the H up to the trailer, hook up and drag them off the trailer. Then you will have to get them home... Hey, atleast I solved half the problem for you :laughing:
/ how to transport a set of drag discs #13
thanks everyone!
How would you flip the disks back over at your destination? :confused: You have an uphill battle on your hands. :( Is this going to be an annual thing or is it a one time thing? Sometimes certain things just are not practical, not to say that it can't be done, just more trouble than it's worth. ;)
I was thinking i would just flip it myself, which i have done before. I think you are correct it seems to be more trouble then its worth. I will just load it on the trailer and pull the trailer with the loader.
thanks for all of your replies
BLUE DIAMOND PL16LF HYD 16" SERIES 2 COLD PLANER (A60429)
BLUE DIAMOND...
Kubota Z232 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2001 Freightliner MB55 Bus (A59230)
2001 Freightliner...
2011 Ford E-350 Cargo Van (A59230)
2011 Ford E-350...
Cushman Electric Cart (A55851)
Cushman Electric...
