How old are your batteries and how to keep them in good shape?
   / How old are your batteries and how to keep them in good shape? #21
The battery in my 2000 Toyota Tundra is 12 years old, The JD GT225 battery is 11 years old, the JD 2720 only 3 1/2 years. All are outside or in the unheated barn. Don't do anything special to them, just check the fluid. The 2 JDs get some winter use but not much.
Just wish I could find a good battery for my rototiller that lasts more than 2 years
Up here in N.S. there is not much of batteries to chose from. I can't even buy an Optima. Closest I come to something like that would be from Canadian Tire called Eliminator. Personally I try to stay away from any battery that I cannot open up. I found with these they have power like crazy for it's size, but are toast the fastest as well. Maybe the Calcium in it? I don't know. Next to these, the Energizer brand from Walmart. Those are junk. Those sulphate even with a quality maintenance charger hooked up to it.
Is actually anyone using actually using an AGM like Optima in their tractors? I wonder how those stand up.
For now I am back into trying to refresh my old batteries and reverse the sulfating process. As long the battery hasn't had any physical damage or shorted or open cell, it should work. I am still a little new at this as I just started 7 months ago with "desulfators" with quite a bit of success.
I heard all kinds of methods like Battery Minder, EPSOM salts, EDTA, and a few "spikers" like electric fence energizer or other little devices. Is anyone using such electronic devices, to revive your old battery?
   / How old are your batteries and how to keep them in good shape? #23
Temps above 77F, vibration, over charging, under charging, deep cycling and tightening the clamps with one wrench will ruin batteries
   / How old are your batteries and how to keep them in good shape? #24
I replaced my tractor battery last year with one from Tractor Supply...
I made sure that I got a fresh one...
The one in front was 11 months old but the one behind it was only 2 months old...
I just replaced both batteries in my Powerstroke...
I got 7-1/2 years out of my old ones...
They did a good job...
I typically like to keep a trickle charger on my tractor in the winter but unhook it in the spring...
That seems to help keep the battery fully charged and last longer...
   / How old are your batteries and how to keep them in good shape? #25
Buick, I have to agree with you...We still don't have good service with the big D-8 batterys and they don't even get shook? Some of the best chargers available. But that starting current is a dooseeey?
   / How old are your batteries and how to keep them in good shape? #27
A couple years ago I replaced the battery in my old JD750, someone had written 1997 on the side of it. Can't complain about 13 years!
OTOH, I've never gotten more than a couple years (at best) from a lawnmower/ATV battery, and the 2nd year usually requires liberal use of a charger.
   / How old are your batteries and how to keep them in good shape? #28
The mowers have 2 whammies on them. 1) the batteries are HOT all the time. 2) the charging circuits often over voltage them (as do some ATV's).
Funny... talking about this... but my dad has the best luck with a lawnmower battery. His battery is 10 years old, never went dead and it and the 2 cyl Briggs just keep on chugging. My big batteries just last a few years and they need to desulphated again. What gives? He lives around the corner and stores the lawnmower in a unheated attched garage. He doesn't even unhook the battery cables. Dunno... what I am doing wrong.
   / How old are your batteries and how to keep them in good shape? #30
I didn't have good luck with Walmart batteries. Those have the highest failure rate.
The same can be said about nearly all the China-made crap that Walmart sells.
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2017 Buick Regal Sedan (A50324)
2017 Buick Regal...
Pitts RGN Trailer (A50322)
Pitts RGN Trailer...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
