hydraulic post hole auger on a TC35
   / hydraulic post hole auger on a TC35 #4
I have used a Post Hole Digger (PHD) mounted to the 3-point hitch on my TC33D a number of times with 6" and 9" augers. In nice soil, no rocks bigger than a softball, and not a lot of clay or shale it works like a dream.
The fun begins when you start to introduce the clay, rocks and shale. By fun I mean breaking shear pins and having to use a large pipe wrench to twist the auger out. I can see the advantage of the hydraulic driven PHD because you can reverse it as long as you haven't broken a shear pin.
Are you looking to mount it on your bucket or the 3-point hitch?
To me the bucket of my TC33D or should I say the structure (hydraulic cylinders, pivot points, long arms) just doesn't seem sturdy enough. If you mount it on the bucket I would think when you dig (especially if you hit hard stuff) the entire structure is going to be dancing around which can't be good for it. Maybe on a bigger tractor this is not an issue.
   / hydraulic post hole auger on a TC35 #5
I have a customer with a MacMillen hydraulic PHD mounted on his TC40D/16LA. No problems after several years of farm use.
   / hydraulic post hole auger on a TC35 #6
jjbath: Are you aware that you put TC35 in your title and TC55 in your post? I'm sure you mean TC55 which has over 2 gpm more flow than the TC35. I would look at the auger manufacturer's specs and use that as a guide.
   / hydraulic post hole auger on a TC35 #7
Do you know which model McMillen? I have the same tractor/FEL (in the Case version), and it may help the OP (and me!) if you could post a model number to look up the specs on.
HH
Yes, I just traded in my tc35 for the 55. Still have the 35 on my brain.
   / hydraulic post hole auger on a TC35 #10
I'm going to mount it to a QA plate.
Mounted on the loader, you will have long runs of hoses 12' to 15' long. I don't know this for sure, but probably 1/2" hose would supply better flow than 3/8" hose. I really have no experience with with how the QA plate augers are set up, but it's worth checking/asking to be sure you get the correct setup. One thing I know for sure. !/2" hoses are far harder to route and deal with than 3/8" hoses. However, if they make a big difference, you have to consider them. Your rear remotes on the tractor will be 1/2" quick-connects.
TPM RM900SB All Terrain Remote Controlled Weed and Brush Mower (New/Unused) (A59225)
TPM RM900SB All...
(1) HD 20ft Free Standing Corral Panel with Feed Bunk (A57453)
(1) HD 20ft Free...
2019 Freightliner M2 106 Johnston VT651 8.5 Yard Street Sweeper Truck (A56858)
2019 Freightliner...
2005 Chevrolet Colorado Pickup Truck, VIN # 1GCDT146258224098 (A57453)
2005 Chevrolet...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
Mini Plate (A57149)
Mini Plate (A57149)
