Power Steering for B7100 and others?
   / Power Steering for B7100 and others? #1
Binder pilot 53
Katie OK
Kubota, Pasquali, Farmall
Has anyone tried replacing the steering box on these tractors with a small P/S box off say a Mazda P.U.? I realize you would have to make a support for the steering column but that can be done. This would be helpful for loader work. I think the next time I am at Pull A Part I will look over some of the import cars and P.U.s to see what may work. Or is there a better why to do this?
   / Power Steering for B7100 and others? #2
I haven't seen anyone using a p/s box off a car, but have seen someone use a pump. I plan on adding one to my setup because I don't like losing p/s when using my loader. Check out the link in my signature for how I did it. There is a bunch of other people's setup on this site you just need to look around. I think some are linked in my post.
   / Power Steering for B7100 and others? #3
I used a power steering pump off a Maxima and a Sauer Danfoss steering valve. The hardest piece to fab was the steering column and support for the dash board. I did not want to use the tractors pump because it was already running my loader.
   / Power Steering for B7100 and others? #4
A recirculating ball power steering box from an old GM product would make a good bolt on in place of the B7100 steering box. Just have to add the steering wheel to the top. Pitmant arm should be easily adaptable to the existing steering gear.:thumbsup:
   / Power Steering for B7100 and others? #5
The problem I found when looking at car steering boxs was the size. There is not too much room to mount a large box.
   / Power Steering for B7100 and others? #7
   / Power Steering for B7100 and others? #8
If'n that be what youse be wantin to use then use it.:D
   / Power Steering for B7100 and others? #9
Sorry, that's all I could picture although my last one like that was brown.
2011 Hyundai Sonata Sedan (A50324)
2011 Hyundai...
2010 Lincoln MKS Sedan (A50324)
2010 Lincoln MKS...
2015 JOHN DEERE 744K-II HIGH LIFT WHEEL LOADER (A51242)
2015 JOHN DEERE...
2023 KAWASAKI MULE (A51243)
2023 KAWASAKI MULE...
2012 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2012 GENIE...
VENTRAC 4500Z ARTICULATING TRACTOR (A51242)
VENTRAC 4500Z...
