Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,268
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Finally picked up a disc and set of plows for the MF 265 that was the FIL.
Bought this Long Manufacting disc harrow. The Model is 960 and I think 425T may be the serial number. Looking on the web I think the 960 refers to the frame size maybe because I have seen photos of the same frame with a total of 20 blades to 32 blades.
When I checked it out this evening I forgot to count the blades but I think there are 28 per the photo the best I can tell. I think it may be considered 8 foot cut. I did see one 32 blade version referred to as 9' cut. It did measure 10' from outside to outside blades on the rear gangs.
Since it was on the ground I could not check the bearings, axles and see all of each blade but it all seemed to be in working order with all sealed bearings intact. The ad stated a $475 price but it was marked $575 but they said since it was posted with the wrong price they would honor the web price vs marked price.
I had another set of new like two bottoms I wanted for $350 but they were $50 away in another direction and since I have to pick up the disc and will go in the F700 there is no addition trip cost with this set that I got for $275 in a package deal. They are very common and not fully complete (discs are missing) but have points that I should never wear out. The main use is to loosen up a hill that I moving to make a fill at the house for a future shop.
Since both pieces will have set outside these will not get to looking much worse. :laughing:
Not sure if they are going to throw in the dog house but I will make a case for it after spending more money on equipment.
