64 Fordson Super Dexta PTO Problem
   / 64 Fordson Super Dexta PTO Problem #1
fireman4074
MF 231S
I am having trouble with my pto when I engage it for example bushhogging it will disengage on its own. It will stay engage until it get in some high grass unless i raise it up. If this is the problem, how do I adjust it. The tractor is a diesel 3 cylinder. I have tried to use a heavy spring to keep it in gear but now that wont work either. It will grind. I check the in/out play on the pto shaft. It is tight with no play. Is there a clutch that need adjusting. Have anyone had this problem and got it fix? IF so, is this a DIY job or shop fix? Do anyone have diagram of the internal parts?
   / 64 Fordson Super Dexta PTO Problem #2
i'm not up on the fordsons.. but if a mechanical sliding colar engaged pto clutch.....bad news.. if there is no in / out play, AND a bunji won't keep it engaged.. you are probably not looking at soemthing like a detent type fix. I'd be looking at the dog clutch..
Soundguy is their any repair manual that you know of that might be helpful in doing this project.
   / 64 Fordson Super Dexta PTO Problem #4
2019 Allmand Night-Lite V-Series 7kW S/A Towable Light Tower (A52377)
2019 Allmand...
2013 PETERBILT 386 TANDEM AXLE SLEEPER TRUCK (A54607)
2013 PETERBILT 386...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
Titan PDG3200 Gas Powered Post Driver (A52377)
Titan PDG3200 Gas...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
