3-Point Hitch injured neck requires special care - seeking info
   / injured neck requires special care - seeking info
once again, this place gets me where i need to go... Pat's system looks like the trick, to me. my main problems are switching back and forth between finish mower and bush hog, and once in a while a post hole driller (the biggest PITA!)
pat's system looks easy enuff, once the initial settings on the stabilizer are measured and marked.
this is my first experience with neck problems, i've had lumbar problems for years and years, degenerating disc disease, spurs, stenosis, etc... lots of bulges, but this is the first actual herniation, located in C6. i nearly went into shock from the pain! holey moley!!! anyway 3 days a week in traction is slowly improving things, but i've got to find something else... pain killers won't touch it. once i get it where it doesn't hurt, i know better than to aggravate it again, for sure!!!
ok, let me make sure... i'm under the influence of this pain killer dope and not thinking as clearly as i should be. i need the type 1 right? for a mahindra 3510?
thanks....
   / injured neck requires special care - seeking info #13
thanks....
I believe you do have a category 1 hitch. To be sure, take a measurement. The category 1 system will fit tractors with up to a 7/8 inch hole in the lift arm.
thanks fellows, i've got everything in my shopping cart, just needed that information to conclude ordering. i have to get a big collar too, they tell me... won't i look great :)
see y'all! this is the best place for info. my mahindra and cub cadet info in the same place.
holey moley! i ordered that from pat's3pointhitchsystem.com right after i posted the above, and received it today (21st)... i didn't check to see where they were located, must be down the road somewhere...
looks easy enough to install... i'm anxious to get into it...
thanks again!
this thing is great... took me about 1/2 an hour to install it and then the first implement i hitched to, a finish mower, i hit it the first try! click! i had to adjust the top link a little longer.
the only way an easier hook-up could be accomplished would be if someone else did it for me. sure wish i'd thought of this...
thanks again!
oh, i've my priorities in line... i'm not ready to go sit on the porch, i'll find a way to do things i need to do. the day will come way too early where i'll finally have to give up and rock, but i'm gonna put it off as long as i can.
see y'all!
John Deere Z997R (A50123)
John Deere Z997R...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50323)
2016 Big Tex 24ft...
2015 GMC Acadia SUV (A51694)
2015 GMC Acadia...
2021 Polaris RZR 1000-4 (A52384)
2021 Polaris RZR...
Roller (A52377)
Roller (A52377)
Deere 331G (A50123)
Deere 331G (A50123)
