Asphalt milling for Driveway
   / Asphalt milling for Driveway #51
they said this rubber tire roller would be replaced by another vibratory roller when it was time to trade it for a new one, because a vibratory roller can do what a rubber tire roller can, but the vibratory was a lot more convenient.
you can ruin asphalt FAST with a careless operator on a vibratory roller.
around here, we dig and stabilize subgrade, use a vibe roller to get density.. then lay crushed lime rock, again.. use vibe to get density, then use a steel non vibe roller.. usually a heavy static trike, and finish roll the rock, then prime it.. then when asphalt hits, a light dual drul steel wheel hits it, and then a traffic roller which is a multi rubber tired roller.. that usually gives the finish surface it's final 'look'.. etc.
I don't know of a single contractor in our area that uses a vibe roller on the asphalt.
soundguy
   / Asphalt milling for Driveway #53
$60.00 a tri-axle, OMG..I wished I could buy some for that.....
Several years back I got them free for the hauling. Now PA is actually using them to pave secondary roads, so they ain't free anymore.:(
   / Asphalt milling for Driveway #54
Vibratory rollers will have a non vibratory mode. If they have a large enough water filled drum they work well for asphalt.
Rollers used for asphalt may depend on what the contractor has available.:)
Don't see many three drum rollers up here in Canada.:)
For asphalt it's usually two steel drums one acting as breakdown and the other with an experienced operator as a finish roller.
   / Asphalt milling for Driveway #55
They cost over $300.00 a load years ago, but were still cheaper than crushed limestone.. I haven't had a price on anything except dirt.. Out of the cut, which is just clay, was $140 a load...last year..
   / Asphalt milling for Driveway #57
Ha, I do now, back to posting #49...Joke was on me, but still that was cheap then too. It has always been high here, and plus, i thought they did pour diesel on it to bind it back together? I will let it go back into archives>>>. #50 just wanted to see a roller...
   / Asphalt milling for Driveway #58
many of our vibratory rollers here, the bulk I'd say, have 2 rubber tires in back, tread tires, and the drum in front.
that would eat asphalt alive. :)
on a rare occasion you see an articulating 2 drum SMALL vibratory roller. just not very common here. I see more 50's era tractors on propane or kerosene than the small 2 drum vibes.. :)
as you say.. what's available..e tc.
soundguy
   / Asphalt milling for Driveway #60
Don't recall mentioning two drum vibratory rollers.:)
a 2 drum vibe, with the vibe turned off is the ONLY way I'd let a roller like that on asphalt. a vibe with tread rubber in back and a drum on front, down here nayway, is a base and subgrade roller.. not a finish roller. I'd fire an employee if I saw them drive one of our vibes across virgin asphalt.. thus.. when you mentioned turning the vibe off and using a vibe on asphalt.. I assumed a 2 drum vibe.
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
LOT: Steel Work Table 36" x 72" w/8" Craftsman Grinder, (2) Lockers (VISE NOT INCLUDED) (A59076)
LOT: Steel Work...
2025 GPS Trailers (A56858)
2025 GPS Trailers...
Toro Groundsmaster 3500-D Sidewinder 3 Deck Rotary Commercial Mower (A56857)
Toro Groundsmaster...
NEW Long Forks (A59000)
NEW Long Forks...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
