Anyone bought Fit Rite Hyd. Top and Tilt?
   / Anyone bought Fit Rite Hyd. Top and Tilt?
The double check valve is designed to lock the cyl movement.
Flow is free in one direction and blocked in the reverse direction until pilot pressure is applied.
When you want to move the cyl, you have to overcome the pilot ratio pressure in the cyl caused by the weight of the implement.
So would you recommend using a top and side with or without the valved cylinder(s) for boxblade and winch with 'scraper' blade use?
Thanks,
CM
   / Anyone bought Fit Rite Hyd. Top and Tilt? #12
If you need float on the blade, the checked valves will not work.
For anything except float, they work great in keeping a set position of the implement.
   / Anyone bought Fit Rite Hyd. Top and Tilt? #13
While having the DPOCV (check valve) vs not having them debate will probably go on for eternity, one of what I think is a big factor in not having them is that while you are grading, how often does a person go between adjustments? 2-3-10 minutes? If your control leaks so bad that it effects your grading, then you need to rebuild or replace the valve IMO. It is a HUGE plus to be able to have your side link float. Now I know that not all rear remotes have the float function and for those people there is no advantage to having a side link without a check valve.
Another thing that I will bring up is that none of the OEM units have the check valves. Not JD, not Kubota, not Case, not Massey, not even CAT. None of the AG or industrial machines have the check valves, why? Because it has been made into an issue that in all reality is a none issue. Do the hydraulics move and or leak down, yes they do. I know on my own tractors I have checked to see just how much they leak in an hours time, it will vary from 1/8"-3/16" over an hour. Is that enough to really make a difference when in use? Not with anything that I do and like I've said before how long between adjustments anyway, a few minutes at most. The few thousandths of an inch that it might drift is so negligible that it is hard to believe that anyone can actually see the difference. Again if it drifts enough that it is a problem, then most of the time the control valve should be looked at and taken care of.
My argument applies to grading, it is a different story regarding farming where you do leave your implement and hitch in the same position for hours at a time.
Nothing wrong with either way of having the links, but there are benefits to each. ;)
   / Anyone bought Fit Rite Hyd. Top and Tilt? #14
My Kubota L5740 has a class 1-2 3 point which means class 2 pins everywhere but the tractor top link. Brian made a cylinder for me with the class 2 end and oriented the ports for me. He was absolutely great to work with, highly recommended!
   / Anyone bought Fit Rite Hyd. Top and Tilt? #15
Thanks Harry. :drink:
2014 FORD F-350 CAB & CHASSIS (A58214)
2014 FORD F-350...
J and L Cargo Express Shadowmaster Enclosed Trailer (A56436)
J and L Cargo...
1996 Timpte 46ft Hopper (A56436)
1996 Timpte 46ft...
2024 Yakta YXR710 Zero Turn Lawnmower (A57453)
2024 Yakta YXR710...
2137 (A58376)
2137 (A58376)
bad boy zero turn 72 (A56857)
bad boy zero turn...
