Old Diesel Fuel
   / Old Diesel Fuel
DO NOT put it in a modern deisel. Its high sulfer fuel and will screw up a modern engine emessions stuff.
I would however assuming it was filtered and had no water run it in my 30+ year old yanmar tractor or use it in the farm house oil burner furnace.
Good point. I have a 2010 JD diesel. Maybe I better nix that idea. I have a 2002 diesel truck and I'll check with another forum on that one.
Edit: Whoops I can't do that. Home fuel can't go in a truck. It seems like the sulfur would be the hang up now. I don't want to screw something up for a couple hundred bucks.
   / Old Diesel Fuel #12
Is it red? If it isn't dyed you can burn it in the truck. There is no way to tell.
   / Old Diesel Fuel #13
I personally wouldn't risk it in my tractor or UTV, but there may be another alternative. I switched from oil heat to a heat pump at my farmhouse a few years ago. I contacted my oil company and they pumped out the tank and paid me the going price for the fuel, less a pickup fee. I'm hazy on the fee, but I think it was $50.
Steve
Its a clue that they knew it was good.
larry
   / Old Diesel Fuel #14
Thanks for the input,
I think what I might do is tilt the tank like 90Cummins suggested and take a sample to make sure there isn't any water in it. Put a new filter on it, check it again and then use maybe a gallon or two in the tank of the tractor at every fill. Hopefully it would be diluted with good stuff. Possibly I might use a little conditioner of some sort. Maybe that would help.
Water is on the bottom. It doesnt spoil the fuel above.
larry
   / Old Diesel Fuel #16
If it were me I'd use it. I'd pump it out with my water block filter and mix it with whatever fuel i already had on hand.
   / Old Diesel Fuel #17
No, it's not red. The other poster had a point, that if a fuel company pumped it out they would know it's good.
My fuel tank had been filled relatively recently when I called my oil company about pumping out the oil in the tank. I was at the farm when the tank was pumped. I didn't observe the truck driver test the oil, but I assume that the oil truck was fitted with some sort of filter to remove contaminants.
Steve
   / Old Diesel Fuel #18
I have a thousand litres of old Diesel, that I should get around to using. It will actually be better for the pumps then the new low sulpher stuff. I wouldn't use it in anything that has a particulate filter on the exhaust. But for older engines or even newer ones under 25 HP that didn't have to comply with ultra strict emissions requirments, no problem.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
2004 MCI D4500 Passenger Bus, VIN # 1M8PDMPA54P056247 (A51572)
2004 MCI D4500...
NEW Wolverine 72'' Skid Steer Ripper (A53002)
NEW Wolverine 72''...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
