NH LX865 Skidsteer Locked Up???
   / NH LX865 Skidsteer Locked Up??? #11
Moisture can enter the gearbox/parkbrake housing causing the water to freeze thus locking the parking brake discs in place. The best solution would be to remove the drive motor and the brake housing cover and clean the housing. While in there you should see one or two holes that have magnets around them. They are probably "fuzzed" over not allowing oil to flow in and out of the brake housing. This is not a difficult fix especially since the 865 was a single speed.
20 20...thanks for your imput
Quote:
I took an equipment mechanic (JD,Case,Volvo, etc) with me the first time to look at it and everything checked out fine.
everything checked out fine but yet it wouldn't work? What did the mechanic suggest was the issue?
I will clarify that when I took the mechanic it was warm outside. It acted up a week later when I went to demo it, It had sat since I ran it and it was below freezing. Also, I've been checking the machine trading/selling sites and have a good idea what this machine is worth and what they are going for....I've learned SS's hold their value unless they are a total POS.
Im also interested in this machine because Im told its the same as the JD 8875? Just different motor and or drivetrain????????????
Thanks Mike10 and RickB as your thoughts on the problem may b the answer. I will check it out.
   / NH LX865 Skidsteer Locked Up??? #13
Okay, now I understand sorry for the confusion. I wish you luck with it, if you decide to buy it.
Stopped by the dealer the other day. He said he couldn't find any water in the gearbox. He doesn't know what the problem could be and seemed frustrated. (He has internet so I don't know why he hasn't checked this site). After being in the warm workshop, the machine operated without any issues. So my guess is the same as Mike10 with moisture freezing the brake. Now, I just need to negotiate the RIGHT price.
   / NH LX865 Skidsteer Locked Up??? #15
The gearbox is setup so oil flows from the gear potion of the gearbox to the brake housing. The holes that allow the oil to flow into the brake housing have a round magnet like a doughnut around these holes. The magnets keep metal from the brakes from entering the gear portion of the gearbox. Works great, but what happens is the magnets can catch too much material and actually plug the holes so no oil can flow into the brake housings. What oil is left in the brake housing can leak or evaporate out and condensation enters the brake housing and when the temp falls below freezing the brake disc will be frozen tight. It is entirely possible that the oil in the gearbox showed no sign of water.
Thanks Mike10. I may demo it in the next few days and make offer.
Got to finally Demo the machine and found it to be a tired POS that I think was flooded at one time or another. Thanks for all of ur help. On to the next........
   / NH LX865 Skidsteer Locked Up??? #18
We do appreciate hearing the outcome. Some of the best deals are the ones not made.
2012 Ford F550 Dump (A55272)
2012 Ford F550...
1645 (A58375)
1645 (A58375)
2017 FREIGHTLINER M2 106 (A58214)
2017 FREIGHTLINER...
2018 Ford Fusion Hybrid Sedan (A56859)
2018 Ford Fusion...
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
Kawasaki KLX140L Dirtbike (A59225)
Kawasaki KLX140L...
