Kubota BX2350 Mid hydraulics arms not lowering
   / Kubota BX2350 Mid hydraulics arms not lowering #1
bx2350 owner
DFW, Texas
Kubota BX2350
Guys....thanks for letting me be a part of the forum that has helped me many times with previous machines!
I just bought a used BX2350 with low hours. I had to transport the machine and removed the 60" MMM and the arms raised and lowered at that time. I just completed all of the 50 hour service (although the tractor has more hours than that) just to be sure everything was fresh. I replaced the hydraulic fluid and filter, checked and cleaned the screen, changed the oil and filter and both fuel filters. I also drained the front axle fluid and replaced that. I have double checked everything and all is working. The only place I was really close to any lines was with the second fuel filter underneath and I have triple checked that I didn't damage anything close. The rear 3pt. work fine...just the mid arms won't move for me to replace the deck. Any ideas?
   / Kubota BX2350 Mid hydraulics arms not lowering #2
Hello. It sounds like the hydraulics are fine if the 3 pt hitch is working normally. Have you checked the mower height knob? It may be set to "Top" which would cause the mower lift arms to stay up.
   / Kubota BX2350 Mid hydraulics arms not lowering #3
That or (less likely) there is something jammed in the height mechanism underneath.
Aaron Z
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
Ford Flat Bed (A52377)
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
A1 MIST SPRAYERS RESOURCES, IN TERMINATOR 60 R LOT NUMBER 42 (A53084)
A1 MIST SPRAYERS...
