Failure rate for 318 Blade cylinder
   / Failure rate for 318 Blade cylinder #11
Welded cylinders are repairable. Keep the $99 in your pocket.
Welded cylinders are repairable, fact. Can you get it repaired for less than $99--nope. Unless you know someone who will do it for less, please let us know.
Thanks!
   / Failure rate for 318 Blade cylinder #12
Thanks!
Contact Alan
ajnadeau1 at comcast dot net
Just an update guys...over the past 2-3 weeks I have been pushing alot of dirt around our new garage with my grandfathers 318 that I put the new angle cylinder on. So far everything is holding up great. One plus I did notice is how much faster the new cylinder operates, it angles the blade a lot faster then the OEM cylinders does..my grandfather is so impressed by the new cylinder, that he wants to order another one to replace the lift cylinder which the only problem with that is that it leaks slightly where the ram comes out (dont worry we will be keeping the old one as a spare)
But thats just alittle update for you guys.:thumbsup:
2016 Chevrolet Cruze (A50324)
2016 Chevrolet...
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
2021 CATERPILLAR 302.7CR EXCAVATOR (A51242)
2021 CATERPILLAR...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
1991 Peterbilt Dump Truck (A50323)
1991 Peterbilt...
