Going downhill with a Kubota L4400 HST Video
   / Going downhill with a Kubota L4400 HST Video #11
Wow steep "hill"! Mandatory 4x4 country right there! :D
R1's or R4's on that beast? I've got a few slopes like that but I don't drive my tractor on them, but you've got no choice to but to follow the ridge line up.
R1 tires. I could have had the R4 tires for no more money but I need all of the traction I can get. I use chains in the winter and it has to be dry or frozen. Every thing here is either up or down with a few in between areas that we consider flat.:D
   / Going downhill with a Kubota L4400 HST Video #13
Reminds me of home:) I have some hills about that steep, but not near a big. Yours go on and on..
James K0UA
If any ground ever gave way that would be a scary situation. That is a nice chunk of property, how many acres is it.
You are right you have to be careful and stay away from the edge. The narrow trail at the beginning of first hill in the going up video has been an established trail for 40 years that I know of and appears to be rock based. There is 80 acres that I co own with my brother.
James K0UA
The videos are just to the top of the hill it would bore you to death driving out the ridge but it is the only way to get there. I leave it in 4WD all the time. Even my BX1500 stays in 4WD. I use to have a 2WD and I kept chains on it all the time and could not go half the places that the L4400 will go.:thumbsup:
   / Going downhill with a Kubota L4400 HST Video #16
Yep same here, only in 2wd on the flatter pieces of pavement. made the mistake "once" of going down a hill with a load of gravel in 2wd and had a "runaway" when the rear tires started to slip and then lost traction..I learned better real quick:eek:
James K0UA
   / Going downhill with a Kubota L4400 HST Video #17
I have a couple hills nearly that steep but no where near as long. I still get a little nervous traveling them. You sir have ba**s that clang to drive up those hills. I got queasy just watching the up hill video.
   / Going downhill with a Kubota L4400 HST Video #18
Those are some hills. We could BBQ all summer with all that wild Cherry wood, UUUUUM!!!
Charlie
   / Going downhill with a Kubota L4400 HST Video #19
Well, I'm not watching the going up video again. I was all clenched up and getting "pucker factor", and I wasn't even really there!! :eek:
Beautiful place you have there. Stay safe on your "hills"!
   / Going downhill with a Kubota L4400 HST Video #20
Very interesting... thanks for sharing! My only other comment would be it that is a "hill" I'd hate to see your "mountains"!!
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
2010 GMC Acadia SL SUV (A55758)
2010 GMC Acadia SL...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2010 Turfco Mete-R-Matic III Pull-Behind Top Dresser (A55851)
2010 Turfco...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
