Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #1
shortthrow50
Banned
2012 John Deere 3520 Deluxe Cab
Just came in from making this setup. I know you can mount them up front but I just didnt like the idea. I couldnt find any other place to mount one other than underneath the right door. It sits higher than the rest of the crap underneath the tractor so clearance isnt a problem. There was already two holes in the in the peice of steel under the door so i used them and some 3/8 inch peice of steel bracket i had laying around. I also, used one of my empty .50 cal ammo cans as the toolbox and painted it. Sorry about the lighting. my flash wasnt working becuase of the battery being dead. Ill have to put some sort of limiter cable inside the lid because it hits the fender if you open all the way. Pretty sturdy and i like it. Probably just throw a chain in there with some pins for the 3 point and whatever else you guys recommend. If you could, post up a picture where you mounted yours. I like to see others creativity. Tool box placement is limited on these tractors
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #2
Thats a good idea for Cab units, its not like you use the RH door all that much anyhow.:thumbsup:
for sure. However, the door does open and the lid doesnt hit the glass. I onl open that door if im outside and i need to raise the 3 point hitch for something.:thumbsup:
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #4
I'm the same....might as well had an opening window instead of door!
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #5
Thanks for the post. Been wanting to put a toolbox on my 3720. You saved me the time of coming up with a plan. Dropped mine off at dealer yesterday to have the bellymower installed. Can't wait to get it back.
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #6
This is great!
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #7
Got my tractor back today. My belly mower is a 7 Iron. It's made by Deere but little different than yours. Think mine is older model. Other than loosing clearance it is great. Very smooth and quiet.
Is it a 72 inch?
   / Tool Box Placement Ideas For 3x20 or 4x20 Cab tractors #9
Yes. 72 inch. I think I'm going to like it.
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
2021 TAKEUCHI TB235-2 EXCAVATOR (A52706)
2021 TAKEUCHI...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A51691)
2024 Wanco...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
JOHN DEERE 8R310 TRACTOR (A54756)
JOHN DEERE 8R310...
