how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #1
shortthrow50
Banned
2012 John Deere 3520 Deluxe Cab
When you need to haul topsoil, Just add another 2 buckets:thumbsup:
Works every time
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #2
now you did it.
you probably will get them started
now you did it.
oh well. I need to get some dirt at my house and i dont have any other means other than to take from one of my jobsites and use my little *** trailer
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #4
You mean you exceeded the capacity and the earth didn't fly off it's orbit and into the sun?
regardless of physics, it didnt happen:thumbsup:
I woulda put more in it but it was already spilling out all over the sides and on the road as i was making turns around bends
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #6
Just one more should be OK. The tractor can handle it.
[ame=http://www.youtube.com/watch?v=WQflR6740AY]Tractor Skidding down - YouTube[/ame]
Bruce
Bruce
Ther was no weight on the tongue of that trailer. thats what bit him in the ***. However, in my situation i would have to be careful as well driving at road speeds with no trailer brakes. Im pretty squared away though because i pull heavy equipment with work trucks and familiar with safe operation in hairy situations. The truck i have in the picture is a pretty heavy 2012 crew cab 2500 dodge cummins with exhaust brake. You dont even know the load is behind you
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #8
You could have doubled your load by filling up the truck bed along with the trailer.
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #9
Out of curiousity, what are the tires rated for? They look to be holding up well!
I'm far from the safety police as I don't think a little overloading is that bad when you consider the safety margain the engineers put into that trailer. Plus I'm sure you have the recommended 20% tongue load which only puts you over by 200 lbs. :thumbsup:
I don't recommend it but have overloaded a trailer or two a couple of times.
At least you have the right truck! ;-)
   / how to make your 5x10 trailer with max capacity of 3k pounds haul 4k pounds #10
Yep, I've carried a few loads that where over the weight rating too, and did it with a truck that was capable of the extra weight. Now if you ask me, I will tell you to get the right trailer for the job. Only because I know my limitations and driving ability, and don't typically know of the person's asking.
2009 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2009 Ford F-150...
42013 (A51691)
42013 (A51691)
2012 Ford Fusion SE Sedan (A51694)
2012 Ford Fusion...
Heavy-Duty D-Ring Shackle Set (A53117)
Heavy-Duty D-Ring...
CHALLENGER MT525B TRACTOR (A51406)
CHALLENGER MT525B...
7033 (A51691)
7033 (A51691)
