Opinions or Experience on Final Drives
   / Opinions or Experience on Final Drives #1
ritcheyvs
Kittrell, NC
Kioti DK45S
Recent posts made me aware that older DK45 models (like my 2006 DK45S) do not have final drives and some newer ones (maybe HST models?) do. For those wondering, the final drive is an additional gearbox that sits between the differential and the rear wheel. Just eyeballing tractors on the dealers lot, it appeared to me that the straight drive (no final drive) design should be stronger and more reliable. But looks can be deceiving.
Question: Has anyone found the straight drive or final drive designs to be superior in terms of reliability? Opinions?
   / Opinions or Experience on Final Drives #2
When I was talking to my local massey dealer, he mentioned that the straight axles are stronger. The diff on straight axle has to be much stronger of course because there's no gear reduction between it and the tires. I assume they use the extra reduction for the extra clearance you can get from the drop and also a smaller diff? Probably if every thing is happy back there, one style isn't weaker than the other and I have to think a simple ring and pinion setup can handle more torque than one that turns 90 deg but I'm no mech eng.
I think for most of use with CUTs, its the front axle that we have to worry about anyways. I know I'm not going to be busting 100's of acres of sod with my tractor, but I will do hundreds of hours of loader work over the years.
   / Opinions or Experience on Final Drives #3
Finials or even outboard planetarys [sp] allow smaller driveline components, they are used quite often in bigger loaders and dozers. So IMHO it is all in the design. If it is designed correctly it should not make a difference. I prefer them actually. CJ
   / Opinions or Experience on Final Drives #4
The old DK45 and 45S use a planetary style final drive.
BTI
BTI
Son of a gun! They sure do, it's tucked up right against the brake pack. It's so compact I never suspected it was there from looking at the outside. Thanks for the education.
   / Opinions or Experience on Final Drives #6
I have had the frontend of my DK45 SEHST a couple of feet off ground and dropped it. I have the rearend off the ground and dropped it. I have hauled a 20 ft log, 30" on narrow end , by draw bar and getting hung up on everything. I think both are designed just fine.
   / Opinions or Experience on Final Drives #7
PS. I am not used to the detent and "float" on the loader and tend to drop front end a lot further than I want to.
2005 Northwood Artic Fox 29V T/A 34ft. 5th Wheel Travel Trailer (A55853)
2005 Northwood...
2014 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A53422)
2014 Chevrolet...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Pelican Statue (A55853)
Pelican Statue...
2015 Ford Focus (A51694)
2015 Ford Focus...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
