Ballast Box Blade
   / Ballast Box Blade #1
foggy1111
Elite Member
Nisswa, MN
Kubota L 3560 HSTC, 805 Loader
I now have about 500 lbs of suitcase weights hanging on my box blade. Found several more on CL for a fair price. :thumbsup: This solves buying a ballast box. The weights seem to stay put so far....but I think I will add a retention bar thru the handles. Maybe a cable.
   / Ballast Box Blade #2
Very nice foggy:D Is that a king Kutter box blade?
Like the receiver hitch too....
   / Ballast Box Blade
My tractor was getting a little light on the rear axel and a few times I have felt a rear wheel come off the ground....even with my loaded rear tires and the box blade on. Not good. Today I lifted some stumps and trees and maxed out the loader.....all the tires stayed planted on the ground. :thumbsup:
   / Ballast Box Blade
Yep.....found it a long time ago at a JD dealer. It was painted green already...and was pretty much like new at the time. He sold it to me for cheap. ($200) Does what I need. :)
   / Ballast Box Blade #5
In your picture, if you would keep the box blade as low as posiable it would also improve your stability by lowering the center of gravity. I wish I had made my BB a long and a low rectangle instead of a square mass, cause sometimes, I lift it too high and that makes me pucker! It's all about the center of gravity, Lower the Better!
Thats a nice 2nd use of your box blade. :thumbsup:
   / Ballast Box Blade #6
Looks good. Curious about the black ones. I have a bunch of the same weights...... a couple of mine (also black) are actually Yanmar weights. They look the same as the JDs, but where the JDs are 42 lbs each, the Yanmar branded weights are actually heavier..... I think 48 or 50 lbs.
   / Ballast Box Blade #7
Well done. :thumbsup: If you find time, could you possibly describe the way that you attached the trailer hitch to your box blade? Thanks.
   / Ballast Box Blade #8
Awesome. I want to replicate your box blade setup EXACTLY. Hopefully yet this summer.
   / Ballast Box Blade #9
Nice set up. :thumbsup:
Do you know what the original weight for the box blade is?
   / Ballast Box Blade
I had an old chunk of 1/4x 2 x 2" angle iron....about 18" long. I simply bought a 2" reciever at the farm store and welded it to this angle. Then I gusseted it to the inside to prevent bending. Drilled holes and bolted it on. Ir's kinda medium duty.....but it seems to do everything I need with it. I had the 6" drop hitch...and that seems to get me under most trailers pretty well.
2008 Kubota M125X (A53314)
2008 Kubota M125X...
2000 WINNEBAGO FORD F550 RV (A52472)
2000 WINNEBAGO...
3 - JACK STANDS (A55745)
3 - JACK STANDS...
2022 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A55973)
2022 Ford F-250 XL...
2013 Honda CR-Z EX Hatchback (A55758)
2013 Honda CR-Z EX...
2001 Ford Crown Victoria Passenger Car, VIN # 2FAFP71W41X143155 (A54865)
2001 Ford Crown...
