Checking gear oil in a Belarus 420AN?
   / Checking gear oil in a Belarus 420AN? #1
novaman68
Member
kansas
John Deere 440, Allis Chalmers WD45, Massey Ferguson 65
I am getting my Belarus serviced and ready to work. I pulled the plug on the bottom of the gear box that drives the front drive line (1st pic). This is the lowest point and the only drain plug I found. I have a few questions. Thanks in advance
1. Am I correct to assume that the transmission & rear end share the same oil?
2. There are 2 plugs (2nd pic)...are these the check plugs for the gear case oil level? If they are, from what I've read there are several configurations of the 400 series, would I use the front plug (higher plug in pic) on a 2wd and the rear plug (lower in pic) for 4wd (my model)
3. There is a large (1 1/4" or so) pipe plug on the floor board to the left of the shifter...I'm assuming this the fill plug for the trans/rear axle...correct?
I bought 5 gallons of 80w90, hopefully this is enough. Thanks again!
Anybody? Surely somebody out there knows something.
   / Checking gear oil in a Belarus 420AN? #3
I have a Belarus 400 2WD and I use the top plug to check the differential oil. The plastic plug on the floor board is how you fill transmission/differential.
   / Checking gear oil in a Belarus 420AN? #4
I have a 400AN and the two plugs for checking are what you have shown in the pictures. The top is the level your oil should be at or below if you have a gear reducer in your tractor, and the lower plug is where your oil should be if you do not have a gear reducer. I have a plug at the bottom of the gear case that I drain from.
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
(INOP) 1994 HONDA 200 ATV (A51247)
(INOP) 1994 HONDA...
2025 AGT MX-CRT23 (A50123)
2025 AGT MX-CRT23...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2018 Forest River XLR Hyper Lite 31HFX Toy Hauler  (A52384)
2018 Forest River...
UNUSED MOWER KING SSRC72-72" HYD BRUSH CUTTER (A51248)
UNUSED MOWER KING...
