NH 3415 Problem starting after using PTO
   / NH 3415 Problem starting after using PTO #1
Darroch
Little Rock, ARK
NH 3415
OK. I have read some similar issues here but have not found a solution yet :confused:
Whenever I have previously engaged the PTO (i.e. bush hogging) and park the tractor for a bit (lunchbreak, etc.) it will not start - not even turn over or any noise from starter. I can "jiggle" the PTO engagement handle while simulaneously turjing the key and it will sometimes fire right up..........but often it will not. Now if I let it sit a day (or 3) and try the juggling/starting again it will fire right up. This only occurrs when I have used the PTO.
I know there must be some sort of switch and/or contact that is responsible, but which/where/how to replace and/or disable it.
   / NH 3415 Problem starting after using PTO #2
pto safety switch is going out or is out of adjustment i would guess
Yes, I understand that the PTO safety switch is going out. What I need to know is where it is located so that I can change it. I have followed the lever down and over to where it inserts into the main body of the tracor, a small "box". Any problems with removing the bolts to look for it there?
2006 TerraGator 8104 (A53472)
2006 TerraGator...
2004 CAT 953C Crawler Loader (A51573)
2004 CAT 953C...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A53472)
LIKE NEW 2023...
UNUSED JCT 72" HYD TILLER (A51248)
UNUSED JCT 72" HYD...
(4) STEEL CARTS W/ WHEELS (A51248)
(4) STEEL CARTS W/...
