F-150 Eco Boost Towing Vs Nissan Titan
   / F-150 Eco Boost Towing Vs Nissan Titan
20% of $4.00/gallon gas is $0.80/gallon. Heck, I drive across the street if gas is $0.01 cheaper. I guess small to some vs others is different.
Yep, tough to convince the flock.:D
Chris
   / F-150 Eco Boost Towing Vs Nissan Titan #32
Lt CHEG said:
Good test. While unlikely that I'll be considering a new truck any time soon, it's nice to see such comparisons. While I guess I was hoping that the ecoboost would have done a little better on fuel economy, from what I understand that's not what it's really all about. As I understand it the ecoboost was designed around people like myself. People that can't or don't want to have two trucks. They need a truck sometimes, and need some decent power sometimes, but also use their truck like a car too. The ecoboost is supposed to use virtually none of that power on tap when driving the truck like a car, without a load, and deliver really great fuel economy when it's not used like a truck (well good fuel economy for a truck anyway). However, when used as a truck and those twin turbos start spooling and it makes more power it uses more fuel, and isn't supposed to be all that much better with respect to fuel economy when towing. If I could average 19 to 20 mpg driving fairly conservatively when driving the truck like a car, but get 11 or 12 when towing, I could certainly live with that tradeoff.
On an unrelated note, I can never understand why the GM 5.3 liter gets dogged so much here. I think it's a great engine, and does a great job of delivering adequate power, with decent fuel economy. With 3.42 gears on my 2009 Silverado I pulled roughly 11,000 pounds (over 1,500 pounds over its tow rating) of tractor, trailer, gear and people up through the Adirondack mountains. I had to drop to about 50 to 55 mph in order to keep the rpms under 4,000 on one particularly steep hill that normally has the 18 wheelers down to 40 mph, but I was okay with that as I'm not in a race when towing anything, even a snowmobile trailer. I was perfectly happy with the performance of the 5.3 liter V8, and only upgraded to a 3/4 ton when I added the backhoe attachment to my tractor which way overtaxed the rear springs and axle on the half ton truck. As someone who owns a GM 6.0 liter V8, owned several 5.3 liter V8's, drives a hemi for work, drove a 5.4 liter V8 powered Expedition for work previously and owns an old 7.3 Powerstroke diesel and owned a 6.4 Powerstroke diesel I still think that the 5.3 V8 is the overall best engine for people that want to own only one truck. Frankly, I probably would have bought a 5.3 V8 equipped 2500HD with 4.10 gears if such a combination was available.
I hope you don't think I was dogging the 5.3 engine. I think it is a proven reliable engine. I was just stating that when comparing engines, pick engines in the same class. The ecoboost would be a closer comparison to a 6.0-6.2 liter normally aspirated engine.
   / F-150 Eco Boost Towing Vs Nissan Titan #33
Diamondpilot said:
The Fords turned in about 15/16mpg empty, 8 towing a real load.
The GM trucks turned in 16/18mpg empty, 8 towing a real load.
The Dodges turned in 12/14 empty, and 8 towing a real load.
Chris
So how many of those Ford and GM trucks getting 15-18mpg were 3/4 ton 4x4's like the Dodge you supposedly owned?
Just trying to keep your data honest...
   / F-150 Eco Boost Towing Vs Nissan Titan #34
Dmace said:
The same reason why someone would compare a 317hp Titan vs a 365hp F150. They're not in the same class either but you didn't have a problem with that now did you Phord Phan? It's comparing truck vs truck not hp vs hp.
You are correct, a stronger engine getting better mileage, why would I contest that?!!!! That is awesome!
You are correct, truck vs truck. Why did you bring the other trucks into the thread?
I am currently a "phord phan", whatever that means? I think all trucks today are pretty good. Certainly wouldn't jump into someone's thread and bad mouth one brand unless instigated.
Dmace said:
I don't think my fuel mileage is great but it's no worse than any other truck making over 300hp. The difference is Ford's marketing campaign constantly pushing this Ecoboost as "V8 power with V6 fuel efficiency". So far I've only seen V8 power with V8 fuel mileage but a ton more complicated, more expensive and more diificult to work on...
You won't admit it but I think you are incorrect. It is worse than at least one truck making greater than 300 HP. 365 HP to be exact. Towing mileage may be the same but riding empty, there is no way your hemi can compete and that is not marketing but real numbers. Come on dmace, bring your engineering mind into the current times and pat fellow engineers on the back for a pretty good engine design.
   / F-150 Eco Boost Towing Vs Nissan Titan #35
It means exactly what you just proved, when someone says something good about a Ford it's great, but when someone else questions those claims all of a sudden they are not making fair comparisons. Can't take the reality?
[ QUOTE="jejeosborne"] You won't admit it but I think you are incorrect. It is worse than at least one truck making greater than 300 HP. 365 HP to be exact. Towing mileage may be the same but riding empty, there is no way your hemi can compete and that is not marketing but real numbers. Come on dmace, bring your engineering mind into the current times and pat fellow engineers on the back for a pretty good engine design.[/QUOTE]
I have no problem admitting the Ecoboost has slightly better unloaded fuel mileage than todays competition. I also stand-by the fact that I'm not impressed by it either, it's a waste of technology and engineering when it's hardly any better than it's aging competition...
   / F-150 Eco Boost Towing Vs Nissan Titan #36
I have no problem with any comparison that has an inequality if the person is showing what should be the weaker item outperforming the stronger one as diamondpilot has done. Of coarse a less powerful engine should get better mileage but you mentioned that it just got the same mileage. Who would want a weaker engine that gets the same mileage besides you?
Why is that hard for a self proclaimed engineer to understand?
   / F-150 Eco Boost Towing Vs Nissan Titan #37
Getting turbochargers into the mainstream is a great thing. We both know that the amount of power a natural-breathing engine can make, with a given combustion chamber displacement, is limited by the amount of air available. With a turbo it's limited by, what, the materials and assembly, right? In other words, it's limited by engineering/technology? Good!
If Ford puts a few million turbocharged cars and trucks on the road, even if I don't buy one myself, that will surely make it easier for my brand of choice to introduce a turbo engine into a market segment that wouldn't otherwise be interested in it, right? Good!
   / F-150 Eco Boost Towing Vs Nissan Titan #38
Did that once. Ended up with a tank full of water!:(
   / F-150 Eco Boost Towing Vs Nissan Titan #39
Regarding all this mileage talk, one needs to consider the OTD price of the vehicles in question, no one brought that up. Just this year as previously mentioned I did buy a new truck, and I looked hard at Ford. I was not convinced their eco was for me, but that is another issue.
The eco window stickered as a $995 option when I was looking. I was interested in the 5.0 so that is where I spent most of my comparison time, but in the end I bought a Ram with a couple more options than the Ford for right about $4,000 less out the door. Throw in the eco option and tack on another $1,000 with tax.
So let's say $5,000 for round numbers.
Let's say that the eco gives 25% better over all economy than the Hemi. Doing the math for say 150,000 miles @ $4.00 per gallon means I still have about $500 left in my pocket. That does not take into account the 3.5% interest that I get on that account. Say it takes me 10 years to do that 150,000 miles and factor in that 3.5% interest and I should net another $500.
So in 150,000 miles of ownership using my real world numbers I am still $1000 ahead of the game with the Ram. Remeber you need to look at all aspects of buying and ownership, not just the difference in fuel mileage when considering cost of ownership.
   / F-150 Eco Boost Towing Vs Nissan Titan #40
If it means more reliable at the same time, everyone else as well.
Compare the newer V8's to the Ecoboost and you'll see stronger engines with basically the same mileage...
When comparing fuel mileage, the EPA is the only accurate measurement for comparison since all the vehicles go through the same exact test. Real world numbers aren't that accurate as one guy on the flat south driving like grandpa could get 20 mpg where another guy with the same vehicle could get 15 mpg in the same area.
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2014 Dodge Charger Sedan (A52377)
2014 Dodge Charger...
Morbark Wood Chipper (A51573)
Morbark Wood...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
