Hatz diesel on 850 BCS
   / Hatz diesel on 850 BCS
Thank you! I was talking to the guy from Continental Engines, and he recommended the 1B50. I'm not certain what the difference is between the B and D series engines.
   / Hatz diesel on 850 BCS #12
The 1B50 would or could be a better fit within the frame cage of the BCS if it has bumper guard and the other issue is the crank elevation of the B50 in relation to the driven gears boring, its depth and height in relation to maintaining the proper center lines of the engine crank and the centerline of the BCS transmission driven gears bore and the other issue is the key slot size of the two parts -crank shaft and female bored gear of the transmission so keep that in mind.
I would chat with the fellow that owns earth tools before I make a decision as they (Continental) may not take the motor back if it was installed and removed.
   / Hatz diesel on 850 BCS #13
Justin,
I don't know why you want to plow new ground with the Hatz Diesel. I too don't like or trust Kohler but they have two crankshafts on the Lombardini engines taht fit the BCS. One is the straight 1" diameter conventional shaft and the other is a short tapered shaft that bolts right on to the BCS transmission with no adapter flange. The last engine is new at least on the BCS 853 but be warned the 6.5x12 wheels and tires won't fit. Lombardini engines have overall been reliable with some problems with starter, wiring, solenoid and key switch. Service has been iffy as most Kohler dealers have never heard of the diesel.
The other engine in the Yanmar L100 which I love. The added weight of the engine helps with the rotary plow balance, large tillers and definitely with the flail mowers. Yanmar engine have not had any running issues I've encountered and are extremely fuel efficient. Martin Diesel in Ohio is very helpful even early on when the engine first used on the BCS. A fire in shed burned the whole BCS but with new tires it was still being used in Montego Bay being started by rope. Martin Diesel had me all the Yanmar parts within a week.
With two proven engines options for the BCS I'd stick with the ones that are supported. You you really want a Hatz engine look at Subaru engines. They are now buying Hatz diesels and reselling them.
Really? I didn't know that.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2024 JOHN DEERE 1025R LOT NUMBER 109 (A53084)
2024 JOHN DEERE...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
Unused Delta Crash...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
