Pole barn construction technique
   / Pole barn construction technique #11
Called a "buried post footing" in the decking trade
The Buried Post Footing - Decks.com
Personally, I'd just as soon use concrete pony walls that extend 24" above grade. No rotting post concerns that way. The fact that you want to stick build your pole barn indicates that you've decided against pole frame construction and that decision would point me toward concrete footings and forget about buried posts altogether.
Good luck.
   / Pole barn construction technique #12
I really like the method that Morton uses to set their post. Makes setting the posts a one man job. They use 3 treated 2x6's that are nailed together and have a metal stilt on the bottom to lift the bottom of the post about 6" off of the bottom of the hole. With the post only about 7 or 8' its easy to handle. They are braced and concrete is poured in the hole which goes around and under the post. With the hole backfilled, the bottom board is attached which establishes grade. All of the post are trimmed to the same height with a 18" stagger between the 3 boards that mates with the top section of the post which gets nailed to the bottom. It makes setting the post quick and easy.
The link below show a lot of good photos.
36x72 morton barn build - The Garage Journal Board
   / Pole barn construction technique #13
now, wont the wood just rot over time?
Wouldnt it be better to do sonotubes of concrete, then simpson or other bracket to isolate the 6x6 from the concrete?
I only ask as I am planning on building a crawl space foundation which I will be mounting a quonset hut on top of :)
   / Pole barn construction technique #14
Roof will be a asphalt shingle.
Ick. Why ruin a good long-lasting building with a poor roof? Go tin. Ick.
I too like the concrete pier instead of the short wood post in the ground.
Pay attention to the joint on the knee wall, as others are pointing out, that needs to be braced right to handle wind-stress on a large wall such as a shed.
--->Pau
   / Pole barn construction technique #15
I see no difference in the buried post method and standard framing on a slab as far as the "hinge" joint you are talking about. As long as the trusses are braced properly the walls will respond in the same manner as any other wall. Picture a house with a full foundation, first floor deck, then 9' or taller walls with trusses, we have never worried about a hinge joint there.
I have never used the Morton method but have often thought about trying it. I think you would have an easier time getting them in a straight line and plumbing them. The last two pole sheds I built were 6x6 posts in the ground 4' sitting on a bout 12" of concrete.
I guess if I knew for sure I was going to finish the inside I would go with the buried post method with conventional framed walls on top. but on the other hand, why not pour an Alaskan slab and just build on it?
   / Pole barn construction technique #16
I was thinking the exact same thing:thumbsup:
As far as cost and ease of finishing, IMO you cannot beat a traditional post framed building.
When I built mine, posts and nailers were cheaper than a stud wall per foot of wall. So that is +1 for post frame.
Post frame is also easier IMO to wire and finish....Well, finishing would be about the same, only the "studs" are running horizontal instead of vertical. But still, on standard spacing, you can still finish with interior sheeting the same way, and the insulation would run horizontal instead of vertical. But as a benefit, you dont have to drill all the studs just to run electric. You can run the wire along the top the nailer (horizontal stud), and when you come to the post, you dont even need to drill the post, because there is the airgap between the post and your exterior sheeting. so +2 for postframe.
And since the posts carry the load and not the entire wall, there is no need for HUGE headers where garage doors and what-not will go to distribute the load. So +3 for post frame.
I really cant see any benefit to a tradition stud wall vs post frame on any single story structure. Infact, if I were building a single story house with no basement, I would probabally do it as post frame.:thumbsup:
   / Pole barn construction technique #17
I don't get it, or any advantage to going this route.
The advantage to pole barn building is the ease, speed and strength of the poles in the ground being part of the walls. There is a lot of strength in this method that allows a minimal amount of material to be used. Pole barns have been around forever, they are proven and they are just about the most economical way to build a structure.
If you want to use stick framing, then pouring a footing and framing up from that would be the way to go. There is no advantage to setting poles in the ground and only coming up two feet, then stick framing on top of that. More work, less strength, without any real savings in materials.
Idealy, pouring a full slab and building up from there would be the best way to go if you can afford it, but that's the big difference between pole building and stick building. Both will give you the building, but one way is more affordable then the other.
As for finishing off the interior, what do you want to put on the walls? You can cheaply and easily install purlins on the inside every two feet and attach plywood or OSB to it for a very nice, solid, interior wall. 5/8 sheetrock works great on 2 ft centers also. You won't spend very much on the extra purlins, all your expense is going to be on what you decide to use for the interior siding.
Eddie
   / Pole barn construction technique #18
I'm with Eddie on this one. Why go through the effort of digging the post holes only to leave two feet of pole above grade? The disadvantage (if it can be called that) of a pole barns is the rotting of the poles below grade. The advantage is the simplicity and lower cost of the main support being the same piece as the wall member.
With this method you get the disadvantage with none of the advantage. Why not just fill that hole with concrete and have a nice strong and relatively cheap foundation?
   / Pole barn construction technique #19
The real key is using wood that is heavily treated for ground contact. The new "treated" lumber that you get at most stores is not suitable to for posts. I know the lumber that Morton used to go under ground is treated to 0.8 pounds per cubic foot of Chromated Copper Arsenate (CCA) to prevent decay.
Three-Member-Laminated-Pine-Columns
The other advantage of pouring around the post is that it is locked in place to prevent pullout by the stilt on the bottom of the post.
In_Ground_Laminated_Column_In_Concrete_Footing
   / Pole barn construction technique #20
I can think of several cases where you don't want to pour a footing. One is near mature trees that are of high value. Digging a foundation will almost certainly kill them unless you try to do root pruning. If you have utilities under the location of the building, it's easy to put in piers/posts to avoid the utilities and still support the building, almost impossible to do with a footing. If you have an underground spring it can cause a lot of problems to trench into it for a footing. My friend did this and had to reroute the spring around the building location, big bucks. Another issue is the type of soil, if the location is on top of a morraine or some area with large difficult rocks, the less you dig the less hair you'll pull out.
It's also not clear why you say piers offer less strength- it depends on the soil and how they're designed. Sky scrapers are only possible because of isolated pier techniques developed to avoid the need for continuous foundations. I think it's not possible to categorically declare one construction technique better than another without considering site specifics.
UNUSED FUTURE 20' WROUGHT IRON BI-PARTING GATE (A57193)
UNUSED FUTURE 20'...
2019 Ford Explorer (A55788)
2019 Ford Explorer...
2017 Chevrolet Express 2500 Cargo Van (A55852)
2017 Chevrolet...
UNUSED FUTURE FT-M48 48" HYD MIXING BUCKET (A57193)
UNUSED FUTURE...
Club Car Carryall 2 Gas Utility Cart (A55851)
Club Car Carryall...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
