SPYDERLK
Super Star Member
- Joined
 - Feb 28, 2006
- Messages
 - 12,485
- Location
 - VA
- Tractor
 - JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
If you are talking full load and rpm [as opposed to hi idle], Id say what you saw would be normal to see in dim light - tho orange is on the hot side. A dull red visible in twilight is normal for full power. What you have now tho shows an imbalance. Take a hard look at your exhaust clearances. After you set them check compression. You may have a burnt valve. Conceivably that could run very hot and cause preignition/ping.I recently purchased a 1999 John Deere 425 with 800 hours. I noticed that when the engine was at full throttle, both exhaust manifolds were glowing orange. This freaked me out so I have been trying to figure out why. I pulled the spark plugs and they had a tan chalky appearance on the tip. I was told this is running too lean.
I took apart the carb and gave it a good cleaning, replaced spark plugs, replaced the air and gas filter, replaced the time delay module, changed the oil/filter and.... Now when I start it up and run at full throttle, ONE exhaust glows red, on the left side. One more thing...it also sounds like there is a pinging noise coming from the same side as the glowing exhaust.
Now, at idle or even half throttle there is NO glowing (but the pinging is definitely there on the left side).
Any insight as to what is going on here? I am just hoping the decision to buy this tractor is not an expensive debacle! Thanks in advance.
larry
