Ford 535
   / Ford 535 #11
does it have a foward/reverse lever are does it have two sticks between your legs
   / Ford 535 #12
Yes, it has a lever to the left of the steering wheel - push it forward to go forward and back to reverse. Only one lever between legs - goes w;here ever you put the lever above.
I know I'm going to have to order a manual for this tractor, just have not wanted to spend the cash at this time. It is a solid tractor and has done everyth;ing I've asked it to do.
Thanks,
paulghorton
   / Ford 535 #13
Thanks,
paulghorton
you have the shuttle trans which has a torque converter for running the trans the only way you could add pto is to get a eight speed trans and rear end out of a 4000, 4600, 3910, 2910, 4610 and do away with the shuttle shift trans and rear end
   / Ford 535 #14
Thanks for the information. I think I will not go any farther with the PTO issue with this tractor. I will use it like it is and go another route per the PTO issue. Could be even another tractor to go with this old work horse.
Thanks for all you information and help
Paulghorton
California foot hills - actually above the foot hills and just below high Sierras.
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
2021 FORD F-150 XL EXT CAB TRUCK (A51406)
2021 FORD F-150 XL...
2013 International DuraStar 4300 Box Truck, VIN # 3HAMMAAL1DL085200 (A51572)
2013 International...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
