Would I have enough amps?
   / Would I have enough amps? #11
Lumber yards have them with dimples that hold the column. They're around 3/16".
You could get a very strong, similar result by welding stubs of pipe to the plates which slip-fit into your columns. Then you can simply bring the parts into the basement, set the plates on the floor, set the columns on the plates, and slide in place.
If you want bolted connections there are plenty of ways to do that, such as weldng "ears" on the columns and tapping some holes in your base plates.
Welding is nice, but careful use of welding in combination with other appropriate solutions is nicer.
I would figure a way not to weld in the basement because I'm lazy. That's a wonderful incentive to efficiency!
Thanks for all the replies. Definitely a few good ideas. The stub pipe method seems to be very practical. The only drawback for me is that I would like to fill the pipes with concrete for added strength.
Maybe I can put the stub on the outside of the pipe. My pipes are nominal 3.5" sched 40 (4" O.D.). I did some research and found out that nominal 4" sched 40 steel pipe has an I.D. of 4.026". That should slide over the column pipes real nice. I think that may be the way to go. Thanks again for the brainstorming session! :thumbsup:
   / Would I have enough amps? #13
What are the numbers on "strength" improvement under what loads with concrete fill, or is that just for giggles?
There is definitely an increase in strength when filling a steel column with concrete. The concrete not only provides additional compressive resistance to the load, but it also increases the buckling resistance of the steel pipe as well. It also increases the fire resistance of the column.
I'm primarily looking for the benefit of the added buckling resistance, because I'm thinking that it will be very difficult to exactly set the base plate perpendicular to the column. Even if I'm a small fraction of an inch off, the weight will still all be on one edge of the column.
Anyway, I'm probably being overly paranoid but concrete is cheap.
   / Would I have enough amps? #15
You should be very careful of any welding after it is concrete filled. The water in the concrete can heat up and cause the concrete to explode. It had happened to people just using their garage floor as a welding table... Probably best to fab something up first then fill it, then bolt it together. Or weld pins to the plate that stick into holes in the concrete or something, but do the welding before concrete.
And don't you find it ironic that someone who's screen name is More Cowbell wants to know if they have enough amps? The answer is Always MORE AMPS!!! :)
I never thought of that. I'm fairly certain that I will be welding a stub pipe to the baseplate first and sliding the concrete filled pipe into it later on so I won't have to worry about that. Although as a novice/amateur welder I do almost all my welding on the slab in my garage. Maybe I should rethink that. :confused:
Good point on the More Amps rule. Now I just need to say it with a Christopher Walkin voice. :D
   / Would I have enough amps? #17
I've got a fever...and the only cure is MORE AMPS! :)
OK. I read all the expert opinion that everyone was nice enough to give, then went and bought that 110v wirefeeder anyway. :eek: (It was on sale at Northern Tool plus I had a coupon). My thinking was that I could do the job by making several passes.
Since the metal is pretty thick (1/2" and 1/4") I set it to the higher of the two power settings and dialed in the wire speed on a pieced of scrap according to the instructions. I was getting some pretty nice test beads on the scrap, but when I tried to weld my pipe columns, it got real ugly. Here is a photo...
(get a barf bag ready...)
It looks like I'm having difficulty getting penetration on the baseplate which is not suprising since it is 1/2" thick. Are there any tricks that could help me out? If there is no silver bullet for this, I'll probably just rig up that extension cord for my 240v stick welder and get it done with that. Thanks.
   / Would I have enough amps? #19
Bird come by and left a deposit?:) Well I am not telling you anything you don't already know.. but part of the problem is you missed the joint, so that is just a practice thing,, BUT..it seems to be badly cold lapped also . Could you heat it up good first with an oxy-ace torch?, that may help. BUT if it was me, I would stick weld that puppy in a heartbeat.:thumbsup:
James K0UA
   / Would I have enough amps? #20
220 welder.
10' Fork Extensions (A56469)
10' Fork...
FAKE (A52472)
FAKE (A52472)
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A53421)
2020 Caterpillar...
Caterpillar 315C L Hydraulic Excavator (A53421)
Caterpillar 315C L...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
Rooster Weathervane (A55853)
Rooster...
