The best way to recondition a gravel parking lot
   / The best way to recondition a gravel parking lot #1
Green Acres Homestead
NewBrunswick & Nova Scotia www.lostcaper.com
Kubota L4740 sold. As of Jan 2023 I have a new L2502.
I guy wants me to fix up his big parking lot. It is very hard packed and muddy when it rains. I could spread 280 tons of grave but it is very expensive. So how can I recondition the parking lot without all that stone expense. I have a tiler which might bring the rocks to the top. Any thoughts on this?
   / The best way to recondition a gravel parking lot #2
Hard packed is good. When you say muddy do you mean there are soft spots that turn into sink holes. If that's the case you have a serious need for a better base or more surface gravel as long as that's not going to sink into the soft spots. If sink holes are not a problem then the lot only needs a bit of a resurface in crushed stone or limestone chips or what ever the gent likes. If you till it I think you'll just make things worse.
   / The best way to recondition a gravel parking lot #3
put down geotextile and 4 inches of 3/4. Be good forever unless the snowplow scraps it off.
   / The best way to recondition a gravel parking lot #4
I re-surface a lot of gravel driveways and parking lots with my Harley rake, it works great!
   / The best way to recondition a gravel parking lot #5
Dr power grader, check it out on their website. I love mine......
   / The best way to recondition a gravel parking lot #6
I've heard the ratchet rake works well for this.
I would not use a tiller!
   / The best way to recondition a gravel parking lot #8
Redo a gravel parking lot!
You need a grader with scarifiers or ripper and a vibratory packer to do a proper job.
Any thing less just moves a few loose rocks into the potholes. Looks good but reverts back to potholes very quickly!:thumbsup:
2014 DRAGON 130 BBL STEEL VACUUM TRAILER (A58214)
2014 DRAGON 130...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2017 Wanco WSDT3-S S/A Towable Radar-Speed Trailer (A55973)
2017 Wanco WSDT3-S...
2015 Ford E-350 Cutaway Van (A55973)
2015 Ford E-350...
