Hydraulic sight class
   / Hydraulic sight class #1
pdqford
Central NY
John Deere 2520
Newbie here - with new (to me) 2520.
What is the correct way to check the transmission/hydraulic oil level?
With the tractor parked on level ground and all the hydraulic attachments lowered, the sight glass looked to be empty. Added a half quart of Hy-Gard and the sight glass looked to be about 1/4 filled.
After using the tractor, parked it in the same place. Next day when I went to use it, the sight glass was completely filled !
Any idea as to what's going on here or what I'm over looking?
   / Hydraulic sight class #2
When I changed my transmisssion oil last fall on my 2520 I thought I had over filled it. I resorted to using the dip stick that is located on the left hand side of the tractor (below the and to the left of the seat). It's kind of a pain to get out, but when in doubt I prefere the stick. My sight glass level did come back to normal after really cycling all the hyrdraulic pieces.
I haven't found a dip stick.
Is the stick suposed to be part of the fill cap?
One manual I have shows the fill cap on the left side of and under the seat.
My other manual shows the fill cap in front of the seat, under the SVC lock lever, where the fill cap is on my 2520. My fill cap doesn't have a dip stick :ashamed:
   / Hydraulic sight class #4
No not part of the dip stick I'll try and fid a photo for you
   / Hydraulic sight class #5
Ok took a couple of photos. The first is looking down alongside the low/neutral/high transmission lever in the low position. Can't see anything no wonder people including me could not find that little devil.
Second photo place shift lever in the high position, and look again (green arrrow poing at the dip stick. White arrow is the transmission lever in high).
You will need skinny hands to reach the stick handle to pull it up. I have a small plastic hook. Then make sure you reseat it good to keep out the dirt.
They didn't want to make it easy for us!
My fill cap it in front of and just below the seat. Yellow cover labled oil. It's just a cap. I used a long funnel to get my new fluid.
My owners manual page 47 (service transmission) step 4 filler cap = B
   / Hydraulic sight class #6
Do you by chance have the FEL attached?
Make sure you retract all the cylinders. Other than that,it should have given you the same sight glass if you did do that and had the 3PT lowered.
As smalltown posted,the stick will give you a better idea of your level. It is a bear to get to though. I was looking my tractor over,and found the darn thing by accident.Why it's in that location,only JD knows.:confused:
Greg
I FOUND IT ! :thumbsup:
Thanks to smalltown's photos ! Who woulda every thought . . . .
Used a large box end wrench to reach down in that inaccessable space and hooked it on the dip stick handle and pulled the dip stick out. :licking:
So now I have one more question:
The markings on the dip stick show an "ADD" line, above which is an "XXX" area. Is the "XXX" area indicating too much oil has been added, or are we supposed to fill it into the "XXX" area?
   / Hydraulic sight class #8
Going to need some backup on this answer!
I cannot find any documentation on the stick itself.
My opinion is that you need to be in the XXX area.
anybody else????
   / Hydraulic sight class #9
That's correct. the xxx area is the normal range.
Okay ! I'm all set then.
Many Thanks for all the help.
This is a great forum :thumbsup:
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55301)
GOODYEAR SET OF...
2006 CATERPILLAR 320CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
