gravel path=giant mess
   / gravel path=giant mess #21
If you have a lumber yard close to you, you can get what they use to wrap lumber in and put those down. They are called lumber wraps (go figure). You can get all you what around here for free. They help a LOT.
Thanks for the great idea.
I will drop by the lumber yard tomorrow on my way home.
I missed Monday evening due to rain.
Tuesday evening to ball hockey.
Wasn't looking good for my Sunday deadline.
Today I hit the ground running!
I managed to set the remainder of the ties in the first hour.
Then my wife Cheryl helped me level, and space all the ties.....ALL the ties!
Tomorrow I'm going to fire up the Kubota and fill the path in with gravel, fill the outside part of the ties with the dirt I removed
Looking good for Sunday deadline.
Attached is the pic with the left side levelled.
It was too dark for a picture with both side done.
   / gravel path=giant mess #23
I hope those ties stay level for you. I was always told you have to dig in and not fill up. I don't envy the work but I am sure in the end you are going to have a very nice walk path. Keep at it.
Ties were dug in, all of them.
I will fill in on the outside where the ground is.
   / gravel path=giant mess #25
Wow, your land is FLAT out there!
Looking good.
   / gravel path=giant mess #26
Looking good.
Yeah, I was thinking that, and, I only counted 2 rocks! That ain't real dirt:laughing:
This is real dirt :D Just kiddin' ya here, good luck with your project.
   / gravel path=giant mess #27
psssstttttt.... the FD recommends extending the top of the ladder 5 rungs above the edge of the roof. This gives you something to grab on to as you step on/off the ladder.
so from the pic, it looks like the path to no were.... you have a barn or something planned for the back of the property?
Actually, OSHA says a minimum of 36" beyond the point of contact with the structure. If FD rule of 5 rungs meets or exceeds 36", that's OK.
I managed to pick up and install 3 lumber wraps as weed barrier.
I'm now starting to think that the lumber wraps are NOT a good idea.
As the are water proof they will not allow water thru.
I'm concerned that the water will sit on the wraps (under the gravel of course) and make the path mushy.
Can someone chime in on using lumber wraps?
RE: picture
I managed to find a few rocks in the tilling process.
The rock by the front end of the tire is the largest I removed from the path.
Hitting this rock was the frst time I heard the slip clutch on my tiller engage...it's a biggie!
I moved the ladder into the garage so as to get into my attic.
I made sure I had 3 rungs over the top and it was much easier to get up and down....especially after a few brews.
Good tip!
   / gravel path=giant mess #30
RE: picture
Maybe poke a few holes with some rod or a fork wherever the water gathers. Your stone will be softer there and depending on clay content of your sub-soil, the water would slowly drain away.
2018 John Deere 333G Track Loader (A53485)
2018 John Deere...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
2014 Ford F-150 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
2001 CATERPILLAR CP-563D PADFOOT ROLLER (A52707)
2001 CATERPILLAR...
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A57024)
Greenworks...
