VaBeekeeper
Member
- Joined
- May 16, 2012
- Messages
- 31
- Location
- King George, VA
- Tractor
- 2016 Kubota L3901 HST with LA-525 front loader
Hi everybody,
I own a Kubota L3240 and am finishing up my 50-hour maintenance procedure. One of the things I've got left to do is check the clutch pedal free travel. Now, I understand that this is the distance between the unpressed position of the pedal and the position at which resistance starts to be felt, and I also see the illustration in the operator's manual; but I still can't seem to wrap my brain around exactly how to make the measurement. The drawing in the manual makes it appear that the clutch pedal travels in a straight line when depressed, whereas the pedal actually swings in an arc. So if I hold a straightedge against the resting pedal, with the straightedge and then move the pedal to where I feel resistance, that pedal is no longer against the straightedge. Exactly how should I hold the straightedge, and how should I take the measurement, to ensure minimum error? I'm probably obsessing over something that should be simple, but different interpretations of how to take that measurement result in much different final figures, and the manual says to stay in the range of 20-30mm.
Thanks!
Thanks!
