Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,642
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
I have owned a small Dresser TD7G dozer for a short time. I am still learning my way around it. It has a 239 cu in air asperated 4 cylinder desiel.
One of the daily maintenence items listed in the op manual is to open a petcock in the bottom of the fuel tank to clear water. This is not practical because it is hard to get at so I do it maybe once every 2 months. I don't get any visable water. I use Stanadyne in the fuel.
Anyway, I have noticed that there is no fuel filter element/bowl/screen between the tank and the lift pump. Just a fuel line, tank to pump. The only fuel filter is a spin on between the lift pump and the injection pump. And there is no water seperator but I assume the spin on will do this OK if changed regularly. Is that true?
I have never had fuel or water problems in my tractor so my fuel supply is probably good. But I wonder if this set up on the dozer is OK as it is or should I add a prefilter and/or water seperator somewhere? If so what is the best and easiest way to do it?
Thanks.
Thanks.
