3038e throttle wont stay revved
   / 3038e throttle wont stay revved #1
freemike
alabama
3038e john deere
81 hours on 3038e and throttle started losing it's rev unless I keep my hand on it. Any help is appreciated.
   / 3038e throttle wont stay revved #2
The friction device on your throttle lever needs tightening. In the attached diagram, items #7 are two nuts. Loosen the first one and then tighten the second one until you get lever tight enough to stay in position. Then tighten the first nut against the second one to hold adjustment tight.
Thanks so much. I really appreciate your help.
   / 3038e throttle wont stay revved #4
I have John Deere 3038E , having the same problem at 140 hr. the diagram does not match my tractor. where can tighten the throttle level. Thanks in advance.
boon.
   / 3038e throttle wont stay revved #5
check to see if any of the wiring is getting pinched / holding the throttle back at full rev where the cable meets the motor - my 3520 had that problem, same engine as 3038e.
2003 Ferris IS1000 52in Zero Turn Mower (A51694)
2003 Ferris IS1000...
2016 Mobility Ventures MV-1 Van (A51694)
2016 Mobility...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
Super Star Smithco Bunker Rake (A50324)
Super Star Smithco...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2015 Ford Focus (A51694)
2015 Ford Focus...
