Hay rake for smaller fields.
   / Hay rake for smaller fields. #1
bjr
Eastern WA
Jinma JM354
All I got is 1-1/4 acres of orchard grass and cut it with a rotary field mower, and would like to rake it up. All I got is KK landscape rake and I tried that with no luck. Is there a drag rake or cheap rotary rake I should look for? I don't know the difference between a tedder a rake? I've seen something describe as a side delivery rake for $600 on Craigslist, but don't know how that works. I've a 35 hp Jinma tractor to pull it with. What should I look for? bjr
   / Hay rake for smaller fields. #2
google side delivery rake on youtube.
youll know one when you see it.
that is typically the smallest easyest to use espeically if its ground driven.
you can get a small tedder that will also windrow depending on weather or not you use a diverter.
   / Hay rake for smaller fields. #3
Look for a 3 point PTO powered side delivery rake. That will work best in small fields ans you can lift it up and over your rows when needed.
Aaron Z
   / Hay rake for smaller fields. #4
Side delivery rakes rake to the side where as centre delivery rake to the middle so you need at least two rotors. Tedders fluff up the forage to dry so you do not want that. Look for a small PTO driven one rotor rake. FAZA or Daros make nice cheap ones.
2025 MS380R Mini Stand-On Track Loader Skid Steer (A53421)
2025 MS380R Mini...
2015 New Holland T4.95 MFWD Cab Tractor (A55302)
2015 New Holland...
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A55788)
2012 Peterbilt 382...
11'x6'8" Sea Container W/ Side Door (A47477)
11'x6'8" Sea...
IRGC40 High-End Mini Golf Cart (A53316)
IRGC40 High-End...
SDLanch SDLLM500 (A53316)
SDLanch SDLLM500...
