Troy Bilt 25 CS weed eater Fuel lines
   / Troy Bilt 25 CS weed eater Fuel lines #1
bamaman01
Member
Section Al
cub LT1042
I replaced the fuel lines on this weed eater due to ethenol gas eating out the lines. Once replaced, I can can get fuel to the primer bubble, but it will not start. Any thoughts on what Imay have done wrong?:)
Thanks in advance
   / Troy Bilt 25 CS weed eater Fuel lines #2
Fuel lines reversed on carb or primer. Junk in the internal screen of the carb.
   / Troy Bilt 25 CS weed eater Fuel lines #3
Did you put the fuel filter back on the gas line in the tank, and you could have the gas lines on backwards on the carb. Did you check the spark plug?
   / Troy Bilt 25 CS weed eater Fuel lines #4
Thanks in advance
If the gas ate the lines, there is a screen in the carb that will be gunked up with pieces of the old lines.
2011 DOOSAN ALL TERRAIN FORKLIFT (A53426)
2011 DOOSAN ALL...
UNUSED JCT 2 PRONG BALE SPEAR (A51248)
UNUSED JCT 2 PRONG...
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2022 CATERPILLAR 272D3 SKID STEER (A51246)
2022 CATERPILLAR...
