is this 99 tn75s a good deal
   / is this 99 tn75s a good deal #1
92b16si
found a 99 tn75s with low hours tires are almost new, he is the second owner. I will be using this with a bushhog and to pull a 2000ltr orchard sprayer. Owner said it runs prefect but third gear went out on original owner hes had it for 5yrs with out a problem . He's letting it go for 10k. Is this a good price? I will be exporting this to mexico so trying to find a deal.
   / is this 99 tn75s a good deal #2
Does it have a FEL? If it does it is a good deal. If it doesnt it might be a good deal depending on what is wrong with the transmission. Fixing the trans could take it to the not such a great deal zone.
no, no fel , i wish it did.
   / is this 99 tn75s a good deal #4
I'd be very leery of a transmission problem. They are often more expensive to fix then the engine! Remember he's sellig it so he's not likely going to tell you that it has a problem.
true , but how much can a used trans or rebuild trans cost? can you even find one?
   / is this 99 tn75s a good deal #8
tractor should end up costing me 13k give or take. Is this a good price
The last guy that asked that question was bying a sound TN 2 WD for something like $5000.
I think I'd run away from that deal as fast as I could. There's too many good used tractors in North America to pay too much for a pig in a poke.
   / is this 99 tn75s a good deal #9
TN75 is a great machine but 13K for a 99 without FEL and 2wd is high regardless of hours.
it is a 4wd. Been searching tractorhouse and the chapest i seen them for is 16k
3 PHASE SEPARATOR (A52472)
3 PHASE SEPARATOR...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51572)
IMPORTANT PLEASE...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
