Woods TSG-50 ??? about vent...
   / Woods TSG-50 ??? about vent... #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Yesterday I reconnected the TSG-50 stump grinder and I noticed there was seepage gear oilcoming out the filler hole on the side of the transmission.
While I was grinding my neighbors little stump for him, he is a retied mechanic, he said my vent was not working and that caused the seepage. We took the vent off (manual also says it is a vent) and the tranny POPPED as I unscrewed it.
NOTHING, not even WD-40 would pass thru the "vent".
So my question is, do I have a defective vent?
Am I running a risk of damage with a vent that does not vent?
Any answers to this perplexing ??? will be appreciated.
Thanks in advance,
Be well,
David
   / Woods TSG-50 ??? about vent... #2
Don't know what your vent looks like, but can you maybe drill a tiny hole in it to allow air to escape?
   / Woods TSG-50 ??? about vent... #3
Well David the vent just ain't for looks. May cause alock on the fluids.
Murph,
It is new and should still be under warranty, do I call the dealer?
David
   / Woods TSG-50 ??? about vent... #5
I'm just thinking out loud and I have no idea what your vent looks like, but in the old Jeeps that I like to mess with, sometimes mud wasps like to block them up. The vents are shaped like a small soda cap over a tube, if you can picture it.
I'd bring it up with your dealer.... something doesn't sound right. I would think that if the vent is failing, excessive pressure might blow out some seals over time.
   / Woods TSG-50 ??? about vent... #6
Use a compressor fitting and a piece of gas line, put a gentle loop in it and an in tank hard gas filter or PVC vent on the end. For some reason those metal vents never seem to hold up and believe me they are supposed to vent unless you like replacing seals, moisture builds up from hot/cool cycles and needs a place to go, think of it like an Axel on a truck, they have the rubber hoses with a loop coming off of them for the same reason.
I use the gas filter setup on my attachments and despite heavy use I have no leaking issues.
   / Woods TSG-50 ??? about vent... #7
Murph,
David
If you can't get it clean and venting easily call him and have him send a couple in the mail. It lives in a dusty dirty laden environment when in use so probably should be checked often.
   / Woods TSG-50 ??? about vent... #8
Maybe painted shut? A service part to check when you check for grease. Put the air hose to it or use a pick to get it open.
   / Woods TSG-50 ??? about vent... #9
   / Woods TSG-50 ??? about vent... #10
David:
Woods vented gear boxes all use the same vent. I am going to assume your vent is stuck. Couple of things we can do for it - one replacement. Second one I am not at liberty to discuss now.
Bring your existing one to the shop BEFORE you use any further.
Thanks
Tony
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
(INOP) JOHN DEERE 730 CRAWLER TRACTOR (A51243)
(INOP) JOHN DEERE...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
Roof Curb (A54865)
Roof Curb (A54865)
1979 MACK R MODEL WINCH TRUCK (A55745)
1979 MACK R MODEL...
