Gas can fix
   / Gas can fix #11
Picked my valve stems up at O'Reilly - it makes a HUGE difference with these new containers.
   / Gas can fix #12
More idiocy from high paid bureaucrats who probably never used a gas can. EPA go away.
   / Gas can fix #13
Awesome! I hate my new cans. This looks like the perfect fix! Thanks. Philip.
   / Gas can fix #14
I think we are saving the enviroment by adding these vents. A couple of minutes of exposing the vapour to the atmosphere has to be a lot better than spilling even a teaspoonfull and we all know that if it was only a teaspoonfull that we usually spill, we wouldn't all be complaining.
   / Gas can fix #15
i'm obviously the only member here who has ever overfilled a fuel tank when pouring from a can (or more likely i'm the only one willing to admit it). i can say for certain that i've spilled no more than several drops of diesel when filling my tractor over the past several years. prior to that i am certain that i've spilled a lot. five years ago, give or take, i bought one of the new style diesel cans with the safety spout and no vent. that spout and the lack of a vent is why i don't spill any fuel. it's pretty much idiot proof. before that i poured from conventional vented cans and there have been plenty of times when the level came up faster than i anticipated, or maybe i was just distracted. either way, i spilled plenty.
i can now stand on the ground and drop my 5 gallon can on the tractor's fuel fill and just balance it there until it stops gurgling. then i pick up the can and i'm done. if there's fuel left in the can it doesn't spill out even when the can is upside down because the spout shuts it off. i can't even see the fuel fill, so i have no clue how close to full the tank is until it stops filling, and i don't need to know. the can does the work for me. not every can and fuel filler pipe is in an advantageous location, but if you have a top fill tractor, then these cans are no-brainers.
   / Gas can fix #16
I posted this fix for a different type of the new cans in the past, not sure if the valve stem would make this type flow better but since the size of the spout remains a constant I doubt it. The pop rivets I use cost a lot less than a $1.50 valve stem.
   / Gas can fix #17
Will a TBN'r please post photos of this gas can modification? Sorry/dial up computer connection won't give me the OP's solution. PICS/PHOTOS PLEASE!!
   / Gas can fix #19
What is the name of the no spill can you have that shuts the fuel off at the spout?
   / Gas can fix
What is this miracle can you speak of?
Galvanized steel Fence (A53424)
Galvanized steel...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
Behlen 150 Gallon Premium Stock Tank (A55218)
Behlen 150 Gallon...
