Watering my pond levee, crude but effective
   / Watering my pond levee, crude but effective #1
Bdavis
Southwest ms
JD1025R
We had a bad drought last year and I did not water the top and sides of my levee. So during the wet winter I really had some bad places develop. I used my FEL and spent about 1/2 day dumping dirt and smoothing out the rough spots.
I purchased a 1600 gallon sump pump from harbor freight 37.00 and the rest of the equipment I already had. ( xpower supply - 1500 watt inverter, scrap wood , wire, and a broken shovel handle). It does not look like much but it
was easy to handle and worked great.
I was really pleased with the output. I did a test before I even used it with a five gallon bucket and it was almost the equal to my well pump. Not sure what the run time is with my Xpower because I got tired of watering after about 30 minutes and put it on recharge.
It appears that your method is a success. :thumbsup:
So far, I am planning on putting a sprinkler on the end of the hose next time so I can do other things while applying the water. Also a sprinkler should allow for a little bit better distribution and not create much run off when trying to apply water to the slope of the levee. If I can get a summer out of this setup , I will be very happy.
Thanks
   / Watering my pond levee, crude but effective #4
cool! never seen or thought about using a piece of lumber as a "skid" to attach sump pump on. and then using a pole to push skid with pump on it, out into the water.
with size of pump you have, you might try coming off the pump outlet a couple feet (what ever size the outlet is) with same size pipe with a WYE, and then reduce down to 2 garden hoses.
that garden hose, can cause a good amount of friction loss. by adding a second garden hose with wye right on pump, 2 sprinklers will not have as much water, compared to just pumping water to one sprinkler. but with 2 sprinklers you should get much larger area coverage.
I do need to change the outlet. The one problem I did find was that coming straight up with garden hose and then bending the hose to follow pole for
support ( a cheap garden hose) does cause the hose to collapse
after it has set out in the sun all day.
I plan to go up with hard pipe from the outlet about 6 inches and hard pipe a elbow and then put a good quality hose on it and that should take care of the little collapse I had.
I had about 10 different designs in my head and was pretty lucky when the
first one I tried worked well. You can't tell from the photo but the pump is sitting on a 4 X 4 block to get it off the bottom of the pond a little higher. The 4X4 block is screwed to the skip plate.
10' CONTAINER (A52706)
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2003 International 4300 S/A Day Cab Truck Tractor (A55852)
2003 International...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
(APPROX.52) UNUSED 2X4X12 LUMBER (A57192)
(APPROX.52) UNUSED...
