is this 99 tn75s a good deal
   / is this 99 tn75s a good deal #14
If you are just bush hogging and pulling equipment, is it worth the price difference for 4x4? I like the 4x's, but you was wanting a deal. Just a thought
yeah i sort of need the 4x4 some parts are in a slope
   / is this 99 tn75s a good deal #17
i would rather have a 5030 for 16k rather then a tn75 for 13k
You mean the "ford" NH 5030, right, not the NH TD5030?
I'm sure you're correct about liking the Ford design better, it is well proven and probably a litle easier/cheaper for new and used parts availability. What are the things that are actually worse about the TN75 or better with the Ford-NH 5030?
   / is this 99 tn75s a good deal #18
yes the 5030 not the td series
the 5030 is a ford design and the tn75 is a fiat design that should say enough
for one parts avalabilty for the 5030 it is a proven desing as for as the trans, rear diff, and hyd's ran from 1976 till the end of production of the 5030 (but pretty much the same from 1965 in the 4000 series) the motor is cheaper to work on and simple to fix
and the 5030 is just a better all around tractor imo
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
JOHN DEERE 7300 (A53084)
JOHN DEERE 7300...
2017 Bobcat S70 Compact Wheel Loader Skid Steer (A51691)
2017 Bobcat S70...
2023 UNVERFERTH 432 (A53084)
2023 UNVERFERTH...
RV Hitch (A50121)
RV Hitch (A50121)
2016 Kia Cadenza Sedan (A51694)
2016 Kia Cadenza...
