Ford 4100 Proofmeter Cable Drive
   / Ford 4100 Proofmeter Cable Drive #1
CTPhil
Gold Member
NW CT
I went to replace my proofmeter cable but am puzzled by what I found. I pulled out the old broken cable end and it had the part in the photo below attached to it. One end has a square hole and had a short piece sticking out, the other round with the broken cable end in it. I can't figure out how it goes back together. Is the square piece supposed to be separate? The new cable doesn't want to go all of the way through and doesn't stick out far enough anyways. Can anyone help?
   / Ford 4100 Proofmeter Cable Drive #2
is that the end off the tack drive under the oil filter if so you will need to remove the oil filter then then remove the bolt in the tach drive cover and remoce it and get a new drive
there should be a cable made onto the end of the piece you showed
So if I understand what you're saying, the fact that that piece is out means the drive head has become unuseable?
   / Ford 4100 Proofmeter Cable Drive #4
So you're saying that piece came out of the back of the proofmeter??
   / Ford 4100 Proofmeter Cable Drive #5
no you can replace just the drive ***. and not the head you just need to remove the head to get the new one back in
It came out with a broken piece of cable where the cable attaches.
I can slide the old piece back in easily enough, I just didn't understand how it works. Apparently the little square piece sticking out the bottom of the piece engages the drive head, and the new cable goes in the other end. Does that sound right? Then the whole thing is held together by the screw cap attaching the cable to the drive head?
   / Ford 4100 Proofmeter Cable Drive #7
yes that sounds about right the little square piece that is broken should be about 1 to 1.5 in long and engages in to the drive head that is under that cover the drive really is the oil pump drive shaft gear which is ran off the cam
Thanks for the help, I think I've got the picture. :)
New/Unused 72in Quick Attach Rock Bucket (A51573)
New/Unused 72in...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2024 JOHN DEERE 9R440 LOT NUMBER 78 (A53084)
2024 JOHN DEERE...
2025 New/Unused Wolverine 32in Hydraulic Backhoe Excavator Thumb (A51573)
2025 New/Unused...
New Land Honor Heavy Duty Plate Compactor (A53002)
New Land Honor...
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
