nuts came loose on front wheels.....
   / nuts came loose on front wheels..... #21
gonna go check my nuts now.....1000 hrs, 'bout time:ashamed:
Got 1 "click" on each front nut...so still very tight.
   / nuts came loose on front wheels..... #22
took your advise got new rim, nuts, bolts & xtras to have . my torque wrench only goes to 160 # i think the required torque is 180 or so #`s.
this time i`m going to tighten the nuts down good & tight.
cm
Time to get a bigger torque wrench. You NEED it!
   / nuts came loose on front wheels..... #23
I know that oversize lug nuts are available in certain sizes for just such an occasion. Whether they are available for your tractor I can't say. You would need to take a lug nut to your local NAPA type store or tractor repair mech. and match it up.
Yes, on a tractor it can be fixed safely in this way if you can find large enuf taper nuts. I would go instead for making taper collars for the studs large enuf to engage the enlarged holes well. These would double as a bushing and a shaped washer held down by normal nut. Looks like the studs are plenty long to allow for the extra space required.
larry
   / nuts came loose on front wheels..... #24
Did that exact thing on my dear, had to replace the studs and all of the hardware, just washered the wheel in the short term and eventually replaced it when I found a used set aroudn for cheep.
   / nuts came loose on front wheels..... #25
Your dear has nuts?:eek:
   / nuts came loose on front wheels..... #26
Yeah maybe you should check your nuts more often. At 50 years old I check mine daily. So far no problems.
Bud
   / nuts came loose on front wheels..... #27
And about that time was when the fight started..
   / nuts came loose on front wheels..... #30
Maybe you could teach the little lady to check your nuts for you? :D
2007 Chevrolet Silverado Service Truck, VIN # 1GBHC24K77E577417 (A57453)
2007 Chevrolet...
2016 Cadillac CTS Sedan (A56859)
2016 Cadillac CTS...
2-ROW NEW IDEA CORN PICKER (A52708)
2-ROW NEW IDEA...
2,500 GAL. POLY FLAT BOTTOM STORAGE TANK (A58374)
2,500 GAL. POLY...
JRB 54" QUICK ATTACH HANG ON WHEEL LOADER FORKS (A52709)
JRB 54" QUICK...
PULL TYPE CONCESSION STAND (A54757)
PULL TYPE...
