Pasture renovation advice
   / Pasture renovation advice #1
corvettefarmer
Bushnell, Florida
2010 John Deere 5083E LTD
After months of renovation work on a couple of rental houses, I'm finally getting back to my tractor work. I have 40 acres of mostly pasture land and
am wanting to level and seed for both beef cattle and horses. I've removed quite a few stumps so the ground really needs to be turned over then dragged to level. I have a large, heavy drag to smooth the land, but have nothing to dig-up, turn-over the ground etc. My question is - if you could only buy 1 piece of equipment, what would you recommend? I live in Florida so the ground is sand. I have a JD 5083 tractor, a couple of mowers, box blade but not much else. I'll be doing this in phases - maybe 10 acres at a time.
Thanks Jim
   / Pasture renovation advice #2
Thanks Jim
The need to turn over to me reads plow. Then you need a disk harrow to do it right. Then a plank drag of some sort to smooth out the work and set the seed. I don't know of one implement that will get all that done.
   / Pasture renovation advice #3
our exprience with making pasture out of wooded land first we took soil samples and went to our local extenision office and what we found out was the dirt on top was a lot more sutible for planting or broadcasting seed than the dirt 4 inches under it all we had to do was put 2 ton of lime per acre we did that every other year for 4 years it's now a hay field with ochard grasss and clover has never been plowed we just tookk a dozer and leveled it the and drug it for the rocks we were told we didn't want to turn the rich dirt under and we didn't i know with all the leaves that had roted and went to soil the dirt was black and the dirt abuot 4 inches deep was alot lighter may be diferent in your area hope this helps depends on how deep you want to go when you turn the ground im not to up on the new types of equiptment but a sod plow souds like what you might use they use them here to turn the ground insted of plowing and discing before planting corn not sure if thats proper name looks kinda like the old type har.
   / Pasture renovation advice #7
As another guy mentioned above, I would be very careful in Florida turning over the ground. You may be ruining the topsoil with a disc plow/ turning plow.
I would recommend a heavy duty disc or even an offset disc.
Bottom line: check your topsoil depth.
   / Pasture renovation advice #8
Here in CNY if someone asked me that question I'd recommend getting a brush hog to knock down the brush and weeds. Just doing that will leave you a nice pasture. I suppose I'd fill in those holes with sand before letting any animals in...esp horses they're accident prone.
   / Pasture renovation advice #9
The bush hog suggestion is actually a really good one.
Thank you for the replies. You have me re-thinking my original plan. I've taken soil samples before and will do again before I start any field work. I'm going to try and get the county extension out and see what they think but I'm leaning towards the suggestion of bringing in sand to fill the holes, drag to even out and then cover the "holes" with some topsoil. I'll update with the county's suggestions and with my final plan.
thanks again
2020 International MV607 2,000 Gallon Water Truck (A51692)
2020 International...
City of Buckhannon -Onan 50 Set Stand By Generator (A52384)
City of Buckhannon...
1998 INTERNATIONAL 4700 4X2 LIQUID TRANSFER TRUCK (A51406)
1998 INTERNATIONAL...
2013 FORD F-150 XL EXTENDED CAB TRUCK (A51406)
2013 FORD F-150 XL...
2016 Great Dane 53FT Refrigerated Van Reefer Trailer (A51692)
2016 Great Dane...
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED (A53843)
2010 UTILITY...
