Why Only 6 Ply Tires?
   / Why Only 6 Ply Tires? #1
robertwhite
Why is it that every new utility 18' trailer I have found only comes with 6 ply tires? Are dealers so cheap that they can't order 8 ply (minimum) tires when they order their trailers? Even with only 3500lb axles, the carry weight could easily be around 3 ton, which flattens out the little 6 ply tires. 8 ply only cost a few bucks more at time of order.
What gives?
   / Why Only 6 Ply Tires? #2
I would blame customers more concerned about price than features or durability. Most people looking at light weight utility trailers don't know the difference between 6 and 8 ply tires all they know is the dealer down the street has what they consider the same trailer for $50 cheaper.
   / Why Only 6 Ply Tires? #4
Nothing new here. Back twenty years ago I went with my brother to Kansas to pick up a stack of three new trailers to bring back to the dealer in Vt. Not long after leaving Kansas we had our first flat. Cheapest thing to do was to take a tire off the top trailer for a spare. By the time we got to VT the top trailer had four flat tires on it.:mad: Know what you need and what they are offering and how much difference that makes in the price you can afford to pay.
With your example of the 3500 pound axle, that's 1750 pounds per tire. That can be handled by many P rated 4 ply tires. So the 6 ply can be more than enough.
Yeah, ummmmmmm. That load of 1750 includes the trailer weight (say 1200lbs or so). Take that 1200 pounds and subtract it from the 7K and you basically have a 3 ton load rating. Now everyone knows that axles are rated WAY under what they can hold, so I should have no problem when I load 3 ton of stone on my trailer. Guess what? The 6 ply tires were pancakes, and that is a problem.
   / Why Only 6 Ply Tires? #6
The axles are rated for what they are rated. And no, not everyone knows that the axles are rated way under what they can hold. It just doesn't work that way.
   / Why Only 6 Ply Tires? #7
If you want to put 3 tons of stone on your trailer, buy the right kind of tires. And trailer, for that matter. Maybe your trailer won't fall apart, but if you get into an accident and a person is injured, you can bet some ambulance-chasing lawyer will investigate whether or not you were trailering safely, and if you weren't, they will use it against you. $0.02.
   / Why Only 6 Ply Tires? #8
I have been looking at trailers to buy and most 'Utility Trailers are just that! Not made to haul big loads even with 3500# axles. They are just for hauling the riding mower and stuff that wan't fit in a pickup. They are built mostly out of angle with the cheapest tires that match the axle rating. Most come with a mesh tailgate a small tractor will crush. UTILITY!!
If you want something that will take a load, you have to step up to the "Equipment Trailers" with channel tongues and better tires. They start at 7K# GVWR (same as your utility) but will cost much more.
A 3500# axle will fail if it is subjected to more than that much weight in time. Tires have to be aired to maximum pressure also.
You might have bought less trailer than what you really need. A new set of tires may also solve your problem.
   / Why Only 6 Ply Tires? #9
you need more than 40 psi of air in them next time :thumbsup: read the sidewall, put what it says they need. (likely 50-60lbs)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2021 Allmand Bros...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2022 JOHN DEERE 331G LOT NUMBER 96 (A53084)
2022 JOHN DEERE...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A55218)
Greenworks...
2019 Dodge Durango (A53421)
2019 Dodge Durango...
