3-Point Hitch MF 165 lower lift arms
   / MF 165 lower lift arms #1
budd4
New Smyrna Beach, FL
Massey Ferguson 165 Diesel
My Name is Bud and I recently purchased a 1969 MF 165 diesel
I need to replace the lower lift arms
I can not find/source the original equipment and I am trying to find after market that will fit. My current ones measure 34 1/2" center to center, cat II at the tractor and cat I at the implement. Any help would be appreciated.
Also I have a question, on the net I located a set of lower lift arms that are heavy duty for a MF 265, they are 38" center to center, cat II at tractor and cat II at the implement, will they work on my 165.
I can swing a wrench, but the tractor is new to the family
   / MF 165 lower lift arms #2
Hello Bud. Here are some PDF files of your lift. It's dark and raining outside or I'd go measure mine to see if those where used on other models. I bet they where. At least you can go online and order them. I'm including the partslist with descriptions and part numbers. I got this info from AGCO Parts Books using the GUEST option. :thumbsup: Hope this helps. -robert
2014 Ford Escape (A50324)
2014 Ford Escape...
2006 Ford E-350 Passenger Van (A51692)
2006 Ford E-350...
2000 Sterling L9513 Winch Truck (A53473)
2000 Sterling...
Kawasaki NR (A50324)
2013 Great Dane 53ft T/A Reefer Trailer (A51692)
2013 Great Dane...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51692)
2012 Trail-Eze...
