MMH
Gold Member
I just purchased a used 4500 JD. It has R4 tires. Thought I had a flat, but when I went to get it fixed found out that the rim is cracked. I have a mig welder and am debating welding this up. I would weld a series of tacks then use a needle scaler to beat back down. This would be done to both sides of the crack. I would finish off by grinding/emery cloth to smooth out. Finally, would install a tube so that I would not have to worry if the weld was airtight or not. Of course, the other option is to spend $189 on a new rim.
Comments?
Comments?
