replacing hydraulic hose
   / replacing hydraulic hose #1
Lazy
Missouri
ford 1920 w/fel and bh, case 470, allis chalmers B 1937, JD 450 track loader, Case vac, 3 cub cadets ford lgt 125, Kubota 2230/60 inch mower.1948 farmall cub 1953 farmall cub
Hi
Anyone have a good way to get to the fiting to remove and replace the hose feeding hydraulic oil to the backhoe? I see no way to get to the fitting unless I remove the loader control valve. the engineer's have out done themself's again.
Charlie.
   / replacing hydraulic hose #2
Hi
Charlie.
How about using offset wrenches? I had to do that with my backhoe. Also needed to remove a couple of other lines in order to access the one I needed to change as I recall.
Thanks for the reply I did try the offset wrench, just no room to work. by the way I forgot the tractor is a ford model 1920 built in 1995. If they had made the port on the valve body extended about 1 inch it would have made replacing the hose a 15 minute job.
Charlie.
I need an easy button
   / replacing hydraulic hose #4
Hi
Charlie.
Looks like you need a set of hydraulic wrenches. Hydraulic wrenches are offset and thinner for those hard to reach spots.
   / replacing hydraulic hose #5
Or maybe a Crow Foot Wrench. Use them with an extension on your socket ratchet drive. [ame]http://www.amazon.com/TEKTON-2575-8-Inch-Crowfoot-10-Piece/dp/B000NPUJNA/ref=pd_bxgy_hi_text_b[/ame]
Hi
I tried all those tools, just no room. but while i was finishing breakfast my wife was able to get a wrench on the nut enough to break it free, I was then able to turn the hose and back it out. Had a new hose made and bought an adaptor to screw into the valve body with a swivel nut I could screw the hose into. used a deep socket to screw the adaptor into the valve body atached the hose to the fitting which is now about 1.0 2.0 inches below the valve body where I can use 2 wrenches to tighten.
Thats my story and I'm sticking to it. I thing I will have to start letting my wife help me more often.
Charlie.
2008 Chevrolet Express Box Truck (A56858)
2008 Chevrolet...
2013 Infiniti G37 Coupe (A54815)
2013 Infiniti G37...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
2014 Chevrolet Silverado 1500 High Country 4x4 Crew Cab Pickup Truck (A56858)
2014 Chevrolet...
2015 FREIGHTLINER M2 BOX TRUCK (A58017)
2015 FREIGHTLINER...
