Heavy hauler: Can this price be beat?
   / Heavy hauler: Can this price be beat?
That should be good as long as it shows the maintenance schedule for oil changes and all the grease points what else do you need for a Kubota. They never break or wear out according to their owners here on TBN.
   / Heavy hauler: Can this price be beat? #22
Gary,
Does your new trailer have stake pockets for tiedowns ?
Also if you find the need, a good source of trailer parts ( the cheapest I've found in Houston ) is Polar , they are at beltway 8 and alt 90 on the east side.
Congratulations on the new trailer and Kubota to hold it down !!
C-ya
Scott
Yes it has stake pockets on the sides and a rub rail front to back
You can view a whole bunch of trailers that Trout Trailer has in Photobucket. Just go to Craigslist search for carhaulers and click on the one for $3095 (new price) with 12,000 GVW. Clicking on one of the small photos links you to the photobucket or just try this link
CAR HAULER :: newtrailerpics004.jpg picture by trouttire - Photobucket
   / Heavy hauler: Can this price be beat? #25
I am picking up a gooseneck from Trout Saturday AM.
I tried to find a better price but could not get close
These are the specs.
102x24 Gooseneck Equipment Trailer
-7000lb brake axles
-2 jacks 12000lb
-3ft dove tail
-spring assist ramps
-locking tool box
-10inch channel drive over fenders
-rub rail and chain pockets
-16inch 10pr tires
- comes with spare
$4595.00 I got a higher price for less trailer
http://i1004.photobucket.com/albums/af164/trouttire/GOOSENECK/IMG_1077.jpg
   / Heavy hauler: Can this price be beat? #26
-7000lb brake axles
-2 jacks 12000lb
-3ft dove tail
-locking tool box
-16inch 10pr tires
- comes with spare
How much does it weigh?
   / Heavy hauler: Can this price be beat? #27
I like the load height of that trailer. I had the big deck over GN and hated it. Nice trailer.
Chris
   / Heavy hauler: Can this price be beat? #29
4000 lbs..
Thats not as bad as I thought but, you can only haul 10K lbs then. Alot of the big gooseneck trailers weigh 7 or 8K lbs.
   / Heavy hauler: Can this price be beat? #30
so if you have them tweek one for ya, have them
-add breaks to the second axle.
-make the fenders bolt on so you can drive over the tires with wide stuff, side load pallets directly onto the axle area, or haul a car, you wont get the door open wide enough to get out with those fenders in the way. (youll be going through the window... ask me how i know)
- have them move the spair tire holder up front so i can side load through the area were it currently is. an operation i do more than i drive up the back of mine.
- have them weld a 2" receiver to the side of the jack post/ bottom of the deck for a winch mount.
- is there 7 pin hook up wired for battery charging of the breakaway battery and is it wired for backup lights? (if not have them run the wire and/or include the lights) Ive been known to turn on my rear faceing tractor lights so i can back up the trailer in the dark with the tractor on it. Even if your tow rig isnt wired for backup lights its more than easy to add a switch between the 12v aux wire that supplies power to charge the bat and the backup wire. you pull up, get out flip the toggle and back the trailer up. park, get out and turn them off.
Id take min in a flat deck version and with the above mods pay $3500 less ramps (i have my own which i like better)
2016 FREIGHTLINER M2 DAY CAB (A51222)
2016 FREIGHTLINER...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
Friesen 110 Seed Tender (A50515)
Friesen 110 Seed...
2003 GMC C5500 DUMP TRUCK (A51406)
2003 GMC C5500...
