Tires Air pressure
   / Air pressure #1
mguitas
Super Member
Schuylkill County Pennsylvania
Massey Ferguson 1423 Hydrostat
I was reading some past posts about air pressure for FEL work. I'm going to set my front tires for 35 PSI. What would you set your back tires for 12 16.5 NHS max air pressure 40 PSI. Just like to see what you guys are running your back tires at. I think my back tires are at 25 PSI now. Thanks.
   / Air pressure #2
I have a MF235 with a FEL, I keep 30 psi in front tires and have my rear tires full of 1/2 water - 1/2 antifreeze mix, filled to up over the top of the rim, when they are upright.
I keep 25 psi in the rear tires, but be sure to have the valve stems at the top when you check the pressure or add pressure.
Hope this helps!
Ray
2011 Ford F-150 Ext. Cab Pickup Truck (A55973)
2011 Ford F-150...
2025 GIYI GY-SZYMJ Hydraulic Stump Grinder Mini Skid Steer Attachment (A56857)
2025 GIYI GY-SZYMJ...
2022 Lonestar (A55973)
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
2013 Ford F-250 (A55973)
2013 Ford F-250...
2019 GALYEAN...
